11-18-2015, 09:19 AM | #1 |
Drives: 2015 Camaro 2LS Join Date: Jul 2015
Axle back question.
So i was wondering, does an Axle back system show any performance gains or is if pretty much just to change sound and looks?
2015 2LS: Cold Air Inductions intake, Airaid Throttle Body Spacer, Vitesse Throttle Controller, MTI Stainless Braided Brake Lines, SS Wheels, Elite Engineering Oil Catch Can.
11-18-2015, 09:33 AM | #2 |
Drives: 2018 1SS M6 Join Date: Nov 2014
Not really. The mufflers are at the end of the line and don't have much effect on exhaust flow. The performance factor comes into play when evacuating exhaust from the engine. High flow cats and headers are going to do that for you. Changing anything behind the factory cats will net minimal gain if any. The cats are the biggest choke point in the system.
11-18-2015, 09:33 AM | #3 |
Drives: 2010 Camaro 2SS/RS Black & Silver Join Date: Aug 2010
Pretty much sound and looks.
STAINLESS WORKS HEADERS-TUNED BY JANNETTY RACING-C.A.I. INTAKE-TAYLOR 409 WIRES-SOLO AXLE BACK EXHAUST-ELITE CATCH CAN |
11-18-2015, 09:34 AM | #4 | |
Drives: 2010 Camaro 1SS LS3 Join Date: Jan 2015
11-18-2015, 09:41 AM | #5 |
No power but some weight loss helps. The originals are hefty.
Ordered 6/19/09 Black on Black 2 SS Delivery 10/14/09! Added CAI, Heritage Grill, DRL Plug and Play Harness
11-18-2015, 09:57 AM | #6 |
Drives: 2014 Red Hot LS3 Join Date: Oct 2014
11-18-2015, 10:05 AM | #7 |
Changing the cats needs to be cut and welded correct?
11-18-2015, 10:08 AM | #8 |
11-18-2015, 10:09 AM | #9 |
Im looking right now, and it looks very expensive lol. It makes me wish the axle backs made a difference because the gibson axle back system is only 300 bucks.
11-18-2015, 10:11 AM | #10 |
Drives: Black 2015 2LS, Teal 1991 RS Join Date: Oct 2015
If the car you have is the 2015 2ls under your avatar then you would need either high flow or catless down pipes. The LFX engine has "exhaust manifolds" built in to the heads. There is a square flange that the exhaust bolts to on each head and that's it. Even with high flow or catless down pipes there isn't a huge power gain until you also install a cold air intake and a tune. Most of the time you're just saving weight over the stock system and changing the sound.
11-18-2015, 10:14 AM | #11 | |
11-18-2015, 10:17 AM | #12 |
No cuts or welds needed to change out the cats. On the LS3, each cat has two bolts that connect to the exhaust manifolds, and there's a clip that attaches them that you loosen for the catback end.
I bought the JBA's and they were around 300 bucks. Most noticeable power increase next to the tune, in my book. |
11-18-2015, 10:20 AM | #13 | |
11-18-2015, 10:36 AM | #14 |
SOLO makes them for the LFX, not sure if JBA does or not;
