11-15-2011, 08:32 PM | #1 |
Drives: 2012 1SS Join Date: May 2011
optima battery
Has anyone put a red top in their v6 yet? If so which size was it?
11-15-2011, 10:07 PM | #2 |
Drives: 2011 Camaro LS M6 Mtv Hbo Ps3 Join Date: Sep 2011
I'd like to know too. Gel batteries have a certain advantage over the standard battery. In my '02 Corvette, the Gel battery was my preferred choice since the ECM and all the wiring was located under the battery. Had seen photos of a C5 Corvette where the stock battery leaked and melted everything under it. Major repair.
12-01-2011, 08:55 AM | #3 |
Drives: 2020 COPO #006 Join Date: Feb 2011
Guys - I'm going to check out the Odyssey PC925. Mostly for the weight savings and I don't have a high electrial load. I've purchased only Red Tops to date without issue but have heard nothing but great things about the Odyssey's.
Simply measure the current battery size and match it up to which Red Top will fit with the most capacity.
2020 COPO #006, John Force Edition 5.7 SC
Gone, but not forgotten: *2019 ZL1 755WHP/782RWTQ *2011 LS V6 375HP, 6 speed *1994 Camaro V6, 5 speed *1985 IROC Z 5.0TPI (special factory ordered 1st new car) *1979 Z-28 4-speed 350 *1975 Camaro 350 Auto (first car owned) RESERVED: *2023 Hummer EV 3X Pickup *2024 Hummer EV 3X SUV |
12-01-2011, 09:15 AM | #4 |
Here is some info that might be useful....it might be dated a bit......
here is some good information By Brand: Braille**: Braille B3121 ----------CCA: 550 ---- weight: 21lb ---------------- CA: 742 Braille B2015 ----------CCA: 425 ---- weight: 15lb ---------------- CA: 574 Braille B14115 ---------CCA: 360 ---- weight: 11lb,8oz ------------ CA: 486 Braille B106 -----------CCA: 210 ---- weight: 6lb,6oz ------------- CA: 283 Westco: Westco Miata ---------CCA: 475 ---- weight: 25lb Deka: Deka ETX30 -----------CCA: 370 ---- weight: 21.7lb Deka ETX20 -----------CCA: 270 ---- weight: 15.5lb Deka ETX18 -----------CCA: 300 ---- weight: 18lb Deka ETX16 -----------CCA: 275 ---- weight: 17lb Deka ETX14 -----------CCA: 200 ---- weight: 12lb Deka ETX12 -----------CCA: 180 ---- weight: 9.4lb Deka ETX9 -----------CCA: 120 ---- weight: 6.3lb Odyssey: Odyssey PC680 --------CCA: 220 --- weight: 15lb / 16lb For MJT* Odyssey PC925/MJT ---CCA: 380 --- weight: 24lb / 26lb For MJT* Optima: Optima 34&34R --------CCA 800 -----weight: 37.9lb --------------- CA: 1000 Optima 37/78 ----------CCA 800 ---- weight: 38.8lb --------------- CA: 1000 Optima 75/25 ----------CCA 720 ---- weight: 33.1lb --------------- CA: 910 Optima 25&35 ---------CCA 720 ----- weight: 31.7lb --------------- CA: 910 Duralast: Duralast 8AMU1R ------CCA: 330 ---- weight: 25lb Marathon: Marathon MAR-8AMU1R-CCA: 320 ---- weight: 25lb By CCA: Optima 34&34R --------CCA 800 -----weight: 37.9lb -------------- CA: 1000 Optima 37/78 ----------CCA 800 ---- weight: 38.8lb -------------- CA: 1000 Optima 75/25 ----------CCA 720 ---- weight: 33.1lb -------------- CA: 910 Optima 25&35 ---------CCA 720 ----- weight: 31.7lb -------------- CA: 910 Braille B3121 ----------CCA: 550 ---- weight: 21lb ---------------- CA: 742 Westco Miata ---------CCA: 475 ---- weight: 25lb Braille B2015 ----------CCA: 425 ---- weight: 15lb ---------------- CA: 574 Odyssey PC925/MJT ---CCA: 380 ---- weight: 24lb / 26lb For MJT* Deka ETX30 -----------CCA: 370 ---- weight: 21.7lb Braille B14115 ---------CCA: 360 ---- weight: 11lb,8oz ------------ CA: 486 Duralast 8AMU1R ------CCA: 330 ---- weight: 25lb Marathon MAR-8AMU1R-CCA: 320 ---- weight: 25lb Deka ETX18 -----------CCA: 300 ---- weight: 18lb Deka ETX16 -----------CCA: 275 ---- weight: 17lb Deka ETX20 -----------CCA: 270 ---- weight: 15.5lb Odyssey PC680 --------CCA: 220 ---- weight: 15lb / 16lb For MJT* Braille B106 -----------CCA: 210 ---- weight: 6lb,6oz ------------- CA: 283 Deka ETX14 -----------CCA: 200 ---- weight: 12lb Deka ETX12 -----------CCA: 180 ---- weight: 9.4lb Deka ETX9 -----------CCA: 120 ---- weight: 6.3lb By Weight: Optima 37/78 ----------CCA 800 ---- weight: 38.8lb --------------- CA: 1000 Optima 34&34R --------CCA 800 -----weight: 37.9lb --------------- CA: 1000 Optima 75/25 ----------CCA 720 ---- weight: 33.1lb --------------- CA: 910 Optima 25&35 ---------CCA 720 ----- weight: 31.7lb --------------- CA: 910 Westco Miata ---------CCA: 475 ---- weight: 25lb Duralast 8AMU1R ------CCA: 330 ---- weight: 25lb Marathon MAR-8AMU1R-CCA: 320 ---- weight: 25lb Odyssey PC925/MJT ---CCA: 380 --- weight: 24lb / 26lb For MJT* Deka ETX30 -----------CCA: 370 ---- weight: 21.7lb Braille B3121 ----------CCA: 550 ---- weight: 21lb ---------------- CA: 742 Braille B14115 ---------CCA: 360 ---- weight: 11lb,8oz ------------ CA: 486 Deka ETX18 -----------CCA: 300 ---- weight: 18lb Deka ETX16 -----------CCA: 275 ---- weight: 17lb Deka ETX20 -----------CCA: 270 ---- weight: 15.5lb Odyssey PC680 --------CCA: 220 --- weight: 15lb / 16lb For MJT* Braille B2015 ----------CCA: 425 ---- weight: 15lb ---------------- CA: 574 Deka ETX14 -----------CCA: 200 ---- weight: 12lb Deka ETX12 -----------CCA: 180 ---- weight: 9.4lb Braille B106 -----------CCA: 210 ---- weight: 6lb,6oz ------------- CA: 283 Deka ETX9 -----------CCA: 120 ---- weight: 6.3lb More info: Braile: Probably Deka rebadged **no info on website on what Temp the CCA and CA test are done at... DEKA: Come with M6 Thread on terminals - you will need adapter to SAE automotive Terminals. Rebadged as BigCrank, Braille and other brands // BigCrank has cheap price . (Proved and discussed on the vwvortex there is a whole thread about it.) Odyssey: *MJT: Metal Jacket + Terminals. Also the Odysseys have battery mounting brakets avaible. Miata Battery: Duralast rates them at 330CCA, Marathon at 320CCA, Westco at 475CCA, make what you want of this info but personally I'm not getting a Westco Battery Made by EastPenn Mfg. Sold under: Marathon MAR-8AMU1R (1Year Warranty) Westco 12V31M (4 Year Warranty) Duralast 8AMU1R (8Year Warranty - apparently WAS avaible at autozone)
12-01-2011, 09:17 AM | #5 |
Drives: 2010 Camaro SS 2SS Join Date: Aug 2009
Optima's blow ass! Don't waste the money...
First time they loose a charge they are almost impossible to recharge. Had one in my Saleen which is stored and forgot to put the trickle charger on it after a drive. 2 weeks later went out to start the car to get in my atic and DEAD...charged it until the next morning DEAD, took it back to Autozone the lady swapped it for an Interstate, gave me back the difference and havent had an issue Over-Rated and Over-priced... |
12-01-2011, 09:24 AM | #6 | |
Hot Rod mag (or Car Craft) recently performed the correct procedure on restoring and correctly recovering completely dead Optima's. They succeeded every time. I can only speak to my experience with them, and to date I've purchased 6 (included a yellow top for standby of my home 1/2hp sump pump), in various cars and trucks, and never have had an issue.
12-01-2011, 01:30 PM | #7 | |
Retired Navy
Drives: 2010 2SS/RS Join Date: Mar 2011
Retired Navy... A Husband. A Dad. A Veteran as of 2011. 2010 2SS/RS A6 - FlowMaster CatBack - I'm not a Amsoil dealer and will never be one. I believe in its capabilities from personal use with oil analysis reports backing up my OCI's. Besides, I know more than most cut and paste Amsoil dealers which are at least 95% of them.
12-01-2011, 01:52 PM | #8 |
Shouldn't have to depend on reading an article from hotrod magazine or car craft for a battery to function correctly, espicially a $190.00 battery. I'll take an $75.00 one and it'll do everything they will for less.
12-03-2011, 06:59 PM | #9 |
Got Boost?
Drives: 2010 1SS RS Join Date: Aug 2011
Still would like to know what Red Top would fix correctley.
12-03-2011, 09:56 PM | #10 |
Retired Navy
There isn't an exact fitment with the Optima's by group code.
12-04-2011, 12:45 AM | #11 |
I have heard good things about oddesey, Last I heard optima was having quality issues with batteries going dead after 6 months. No optima for me.
But I would like to know what fits. |
12-04-2011, 02:26 AM | #12 |
My battery guy at work is trying to figure out what odyssey fits the best then I will let you guys know.
12-04-2011, 09:20 AM | #13 | |
Retired Navy
For our Camaro's the correct Odyssey is PC1220. http://www.odysseybattery.com/batterysearch.asp
12-04-2011, 11:01 AM | #14 |
RED TOP suck!!!
Similar Threads | ||||
CTEK Multi US 3300 Battery charger available at www.gmpartshouse.com | patrickt | Audio / Visual / Electronics/ Gauges / Nav | 15 | 03-02-2012 02:20 AM |
Optima yellow top battery | Supercharged2SS | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 0 | 06-24-2011 09:06 PM |
Red Top Optima Battery | smtty025 | V8 - Engine, Exhaust, Bolt-Ons, Tuning Equipment | 2 | 01-21-2011 08:57 PM |
Unrestricted Motorsports Camaro selected for 2009 Optima Battery/ Hot Rod Magazine Ul | tribone | 5th Gen Camaro SS LS LT General Discussions | 32 | 11-16-2009 06:03 PM |
GM To Build Battery Plant | Mr. Wyndham | General Automotive + Other Cars Discussion | 5 | 01-13-2009 01:03 PM |
