Old 07-07-2010, 05:12 PM   #1
motor1
motor1's Avatar
Drives: 2010 Camaro 1SS/RS/M6.....no longer
2 sides of a tune
I have read all the threads about tuning and see now that 1 of them has been closed. I have read where the Mods speak of fraud, etc when the consumers try to circumvent the warranty denial by returning their car back to stock before taking it in for repairs. The problem I have is that this type of behavior would not take place if the manufacturers stepped up and repaired things under warranty when they should be. I have NO personal experience with warranty denials but have read the STORIES. If you destroy a transmission due to a TCM tune which changed the shift points past redline, etc..and a warranty is denied then that is understandable. On the other hand if you mildly changed the shift points for a better shift and the warranty is denied due to just having a tune then that is ridiculous. It is this type of blatant warranty denial across the board just because a tune was installed that makes no sense. Maybe I am missing something but manufacturers seem to just deny it immediately if you have a tune regardless of the specific reason for part failure. Maybe someone can provide an example of warranty claims because I do not have one to refer to.
motor1 is offline   Reply With Quote
Old 07-07-2010, 05:53 PM   #2
Eric Baker
Drives: Black/Black 2SS/RS 6M
The problem is, the dealer making the repair has no way to tell how severe the tune is. As far as they know, the tune did cause the failure, even if it really didn't, because they can't go in and look at the parameters and values.
Eric Baker is offline   Reply With Quote
Old 07-07-2010, 08:13 PM   #3
FLYNNZL1
Wicked ZL1
FLYNNZL1's Avatar
Drives: 2017 ZL1 A10 HBM
Send a message via ICQ to FLYNNZL1 Send a message via MSN to FLYNNZL1 Send a message via Yahoo to FLYNNZL1 Send a message via Skype™ to FLYNNZL1
Be careful, it seems like Facebook is influencing everything, have a discussion on a hot topic, and have your tread closed. At lest give the reason on the last post way it was closed, this will give all of the followers and posters a heads up.
2017 Hyper Blue Metallic ZL1 A10/CF Hood Insert/PDR/NAV MODS: Rotofab CAI/V-MAX CNC Ported Throttle Body/Clear Bra/LED Reverse Light/Rock Guards/Lift Pads/Darkened Tail Lights/Ghost-Tinted LED Side Markers/Darkened 3rd Brake Light
FLYNNZL1 is offline   Reply With Quote
Old 07-07-2010, 08:15 PM   #4
Milk 1027
Camaro➎ moderator
Milk 1027's Avatar
Drives: '13 BLK 1LE
wut?
Old 07-07-2010, 08:19 PM   #5
motor1
motor1's Avatar
That is my point, if they cannot prove it was the cause then why just assume. I can destroy a transmission without a tune and they have to prove it was abuse..just saying
Old 07-07-2010, 08:26 PM   #6
FLYNNZL1
Wicked ZL1
FLYNNZL1's Avatar
Originally Posted by Milk 1027 View Post
wut?
I am not trying to "flame" the fire, on the last post of the last closed "Tuner" thread, it was closed with little to no explanation, if you got the power to close a thread, at lest give a brief explanation, like, I have closed this tread because ..... Thats all, please don't boot me for speaking up jk
Old 07-07-2010, 08:31 PM   #7
Milk 1027
Camaro➎ moderator
Milk 1027's Avatar
Drives: '13 BLK 1LE
It was closed because some people can't discuss like adults when someone else thinks they are wrong or has a different opinion than them. The thread was just beating on a dead horse. Tunners can't prove that their claims are true and they seem to not want to. So what's the point of arguing in a circle?
Old 07-07-2010, 08:37 PM   #8
FLYNNZL1
Wicked ZL1
FLYNNZL1's Avatar
I agree, I get frustrated too at endless loop discussions on this subject. Lets talk about how cool our cars are
Old 07-08-2010, 07:43 AM   #9
DSteck
Drives: 2006 Corvette Z06
It's easy to say that when it's not your money being lost.
The fact of the matter is that they warranty their vehicle in the state that it leaves the factory. That is the state that it's been tested in, and that is the state that the OEM will stand behind. If you change the tune, however trivial it may be, they did not gaurantee the vehicle in that state, and consequently have no liability to stand behind it if there's a failure. On top of that, THEY WARN THE CUSTOMER ABOUT VOIDING THE WARRANTY! That's like having a sign posted that you're entering a construction zone, and the speed limit is lowered... yet you still speed anyway, get pulled over and ticketed, and then bitch about the ticket.
Yep. I tell everyone that I have zero gaurantee that the tune will go undetected after being flashed back to stock, and on top of that, tell everyone I don't support doing it.
DSteck is offline   Reply With Quote
Old 07-08-2010, 08:00 AM   #10
motor1
motor1's Avatar
I understand exactly what you are speaking of and agree, my problem arises when I read about warranty work being denied when it was OBVIOUS that the tune had absolutely NOTHING to do with the problem. I cannot site an example because it was a while back. The perception is that if they see a tune all bets are off and I feel that is what has consumers worried. Now if you Cam your car and drag it then theres no question, but a simple CAI and a tune should not be the catch all for the manufacturer and that is how it seems to be.
Old 07-08-2010, 08:10 AM   #11
Dr Jkel
and MR. HYDE
Drives: 2010 2SS RJT/BLK 6Spd Man
Am I wrong? If you mod your car and have it tuned, the reason you have it tuned is to make the car run and if you change back to stock your car will not run, well at least mine won't. So why would you want to change it back. Thoughts
Dr Jkel is offline   Reply With Quote
Old 07-08-2010, 08:45 AM   #12
DSteck
Please provide me a case where somebody blew their engine and was denied warranty work because of a tune. Dealers don't just randomly check for aftermarket calibrations, and decide to deny your warranty.
I have zero problem with a dealer denying ANY powertrain warranty if there's a tune on the vehicle.
Old 07-08-2010, 09:37 AM   #13
2SSCAMARO
2SSCAMARO's Avatar
Drives: 2010 Camaro Auto
The fact that the thread was beating a dead horse was very obvious many pages prior. Many times readers were advised that if anyone has any reservations about the effects on warranty and are not willing to take that risk,then they should not mod or tune. Is there any ambiguity in that advice?
Those interested in looking out to help members who would like to mod or tune could do this... Write to Obama and his minions who favor redistribution of wealth and debt and who now owns and operates GM on behalf of the tax payers. Based on that premise they could increase the price of all cars sufficiently so that the warranty costs experienced from tuners and modders are spread out among all vehicle owners. Seeing as non-modder/tuners outnumber modders probably thousands to one and many of the non-modders violate their warranties in numerous other ways yet reap repairs fraudulently, it seems an equitable way of doing business.
2SSCAMARO is offline   Reply With Quote
Old 07-08-2010, 10:12 AM   #14
FLYNNZL1
Wicked ZL1
FLYNNZL1's Avatar
Your first part, I understand, the second just does not make sense . GM has paid off it's debt already, back in April, where have you been?
Source: http://money.cnn.com/2010/04/21/auto...ment/index.htm
and the rest is the dead horse you were refering too.
SS A6 or M6 faster?????? MY2010SS 5th Gen Camaro SS LS LT General Discussions 275 05-20-2010 04:15 PM
Pre-Camaro5FEST, FREE DYNO & TUNE SPECIAL!! Qwkss USA - Great Lakes 1 01-27-2010 11:19 PM
Pre-Camaro5 FEST, FREE DYNO & TUNE SPECIAL!! Qwkss USA - Southeast 1 01-27-2010 11:17 PM
Tune now or tune later brtaus Tuning / Diagnostics -- engine and transmission 1 01-27-2010 12:20 PM
Lets play a game 2SSRS@Gen5diy Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 56 09-26-2009 09:08 AM
