10-09-2014, 09:11 PM | #1 |
Drives: 2010 camaro SS/RS Join Date: Dec 2012
anyone using virtual dyno?
can someone point me in the right direction on how to use virtual dyno and HP tuner. it wont except me Log run
Thanks in advance |
10-09-2014, 09:32 PM | #2 |
Drives: none Join Date: Aug 2011
Try the how to thread in the HP Tuners forum lounge.
I goofed around with it for the first time the other day, took maybe 10 minutes to figure it out. |
10-13-2014, 12:31 PM | #3 |
Too much is never enough!
I had not heard of Virtual Dyno until I came across this posting. I loaded some of my Dyno logs into the program and its almost spot on! I got 420hp and 415 tq when actually that specific run was 413/397
What is cool is that even though it was not dead on....the overlays of all the runs I did were very accurate. They looked just like the overlays on the dyno screen.
