06-02-2011, 08:24 AM | #1 |
Drives: 2010 camaro Join Date: May 2011
drop springs or trailing arms
Foundation will be set in regards to cradle and radius bushings but I have an autocross event June 18th and would like some opinions on wether to get drop springs or trailing arms? I can only get one or the other unfortunately right now so what do you think will be better for me or should I say, what would benefit me the most in the autocross?
Besides intake and shorty shifter and soon to be the foundation, the car is stock. LS3 Thanks for the help! |
06-02-2011, 08:37 AM | #2 |
Drives: 2014 Z28 camaro Join Date: Sep 2009
IMO I would put the springs in since you have already fixed the bushings on the cradle and raduis arm bushings.
06-02-2011, 09:50 AM | #3 |
or do you go with sways intead of the springs?
06-02-2011, 11:03 AM | #4 |
Shop Owner
Drives: 1 ton silverado Join Date: Jan 2009
After fondation Springs then sways
06-02-2011, 11:43 AM | #5 |
Drives: Camaro Justice Join Date: Jun 2007
What they said!
06-02-2011, 11:47 AM | #6 |
Drives: 2010 Camaro, 2006 Z06 Join Date: Feb 2009
For immediate benefits for Autox I would suggest sways rather than drop springs. There will be an increase in wheel rates with an increase in spring rate and the lower center of gravity is nice... but the biggest bang for the buck and biggest change in the balance of the car will come with Sways.
Sway bars certainly make the car a lot more fun to drive, especially at the Autox! |
06-02-2011, 12:47 PM | #7 |
Foundational bushes, damping, coil or coilovers and sway bars as the final tuning element is our philosophy on suspension builds. We believe in it and follow it with good results. That doesn't make others wrong. It just makes Pedders, well Pedders.
06-02-2011, 04:17 PM | #8 | |
Similar Threads | ||||
BMR or Pfadt Trailing Arms | ITGuy11 | Suspension / Brakes / Chassis | 55 | 05-20-2011 12:26 PM |
Phastek 1.5"/1.4" Drop Springs in stock | Sean@Phastek | Suspension / Chassis / Brakes | 1 | 05-27-2010 11:22 AM |
Spohn Tubular Rear Trailing Arms & Toe Links | SpohnPerformance | Suspension / Chassis / Brakes | 7 | 10-22-2009 02:17 PM |
PEDDERS TAKING ORDERS FOR DROP COILS WITH OPTIONS! | Info@PeddersUSA.com | Suspension / Chassis / Brakes | 25 | 08-03-2009 10:45 PM |
