04-23-2011, 07:33 AM | #1 |
Drives: 2ss camaro Join Date: May 2010
c6 z06 rims 40mm offset
I know the 40mm z06 will fit the back of 5gen camaro ss but will they fit the front.
05-05-2011, 09:19 AM | #2 |
I was wondering the exact same thing???
05-13-2011, 02:53 PM | #3 |
Drives: 2011 2SS/RS Join Date: May 2011
I thought they were differant lug patterns?
05-14-2011, 08:18 AM | #4 |
They will bolt up on the back with no problem. It is the front you have to worry about because the offset if I'm not mistaking.
05-14-2011, 09:25 AM | #5 |
gotcha
05-14-2011, 09:31 AM | #6 |
The factory rear 20x9 wheel is a +40mm offset and it fits perfectly with the OEM Pirelli P Zero 275/40/20 tire on the front. A 285/35/20 or 285/40/20 tire won't fit, it will rub on the strut housing. Since the ZO6 wheel is 18" or 19" diameter you will have to see if it clears the steering knuckle where the 2 bolts retaining the front strut are and if it clears be sure you don't go wider then a 275 tire or the tire may rub the strut housing. In any event it will be close.
Ed M.
RJT 2SS/RS, AAM 3.70's, MTI Sway Bars, Shifter & SS brake lines, ZLI calipers, rotors & pads, BMR Trailing & Toe Arms, rear cradle & diff bushes, Pedders XA's, Camber/Toe eccentrics, Radius arm inserts, GTO clutch reservoir, LS9 cam, Comp valve springs, Melling 10296 oil pump, CR5 timing chain, LS6 damper, CAI Cold Air Intake, ARH LT headers w/HF cats, GMPP touring axle back, Elite Engineering Catch Can, Forgeline 20x9.5 & 20x11 DS3 whls, 275/40/20 & 315/35/20 tires, 2011 Convertible spoiler, 1LE front spoiler, Lloyd "SS" Floor Mats, GM Camaro Trunk Mat, wrapped console & Grant steering wheel.
06-01-2011, 03:27 PM | #7 | |
Drives: 2010 Camaro SS Join Date: Jan 2011
what you talking about willis? I tried fitting the C6 Z06 rims on mine but they didnt fit in the rear. the tires were rubbing the inner well way before they were completely on the rotor... Bolt pattern is the same though.
2010 camaro 2ss LS3
Corsa catback exhaust w/muffler delete, hennessey intake, Pfadt springs, Hurst Short throw Shifter, Murdered black. GO TEAM LS3 |
06-03-2011, 10:01 AM | #8 |
J.Sick
Drives: 2010 Camaro SS Join Date: Nov 2010
"J.Sick"
2010 Camaro 2SS |
06-03-2011, 10:02 AM | #9 |
J.Sick
I have them on the rear of my car with ET streets 305/45/18's.
"J.Sick"
2010 Camaro 2SS Last edited by jasycz28; 06-03-2011 at 10:13 AM. |
08-01-2011, 03:14 PM | #10 |
You fit C6 Z06 rims on the rear of your camaro?? Can you please PM me on how this was done? im very interested.
2010 camaro 2ss LS3
08-01-2011, 04:36 PM | #11 |
Quit being a pu$$y
He is more that likely using the front Z06 wheels on the back of his Camaro. The stream roller Z06 rear wheels won't fit on our cars.
08-02-2011, 12:40 AM | #12 |
J.Sick
Yes.
"J.Sick"
2010 Camaro 2SS |
08-03-2011, 01:09 AM | #13 |
Drives: 2011 Camaro 2SS Join Date: Jun 2011
if they have wheels widening, would they have wheel thinning? i want the brand new Z06 carbon package wheels! (black zr1 wheels)
Similar Threads | ||||
do rims that fit on c6 corvette, fit the camaro? | ls7camaro | Wheels and Tires Talk Sponsored by The Tire Rack | 4 | 04-22-2010 06:42 AM |
C6 Z06 flyby... freakin-a | CamaroSpike23 | General Automotive + Other Cars Discussion | 20 | 05-05-2008 11:58 AM |
2007 Chevrolet Corvette Z06 Ron Fellows Championship Edition | KILLER74Z28 | General Automotive + Other Cars Discussion | 14 | 04-10-2007 09:29 AM |
