05-26-2011, 04:09 PM | #1 |
Drives: 2011 camaro 1SS Join Date: Aug 2010
oracle switchback turn signal bulbs help needed
help s.o.s. purchased a set of the switchback front turnsignal bulbs from aac oracle with the resistors. i have non rs headlights the eagle eye replacment lights to be exact with the halo ring. ok my problem i install the resistor to the blue turn signal wire and to the black ground and install the bulb and i get both the white and the amber flashing instead of flashing amber. this is the second set i have received. please if anyone has installed these successfully please help a brother out. thanks. also i have installed without the resistor and get the same result but with hyper flashing..
05-26-2011, 10:21 PM | #2 |
Drives: 2011 Camaro 1SS/M6 Cyber Gray Met. Join Date: Jan 2011
If you have your turn signal bulbs turned on and hit your blinker, they will blink orange while the white stays on as well. If you leave them off and put your turn signal on, it will be orange only. I had to take a pair of duck billed pliers and really mash down on my spicers as well.
2011 1SS/LS3 M6--Vararam CAI-Corsa catback-Dynatech LTs-RX Catch Can-Vmax ported TB-Eibach Springs-Night Fury Camshaft- 486RWHP/458 TQ
05-26-2011, 10:22 PM | #3 |
And your car is a 1SS, not an SS1...that drives me nuts
05-27-2011, 12:13 PM | #4 |
hahaha ok for helping me out ill fix that right up for ya! ill try your fix.. cuz right now the flash at the same time.. no switching at all.. thanks again
Similar Threads | ||||
2010-11 Camaro ACC LED Side Marker Mods for Turn Signals | GearHeadPeter | Cosmetics and Lighting Modification Discussions | 44 | 03-13-2015 02:25 AM |
Front turn signals mod ! HELP! | CamaroVicious | Cosmetics and Lighting Modification Discussions | 28 | 11-25-2014 12:51 AM |
Oracle HOD Input Needed (solution to yellow halogen) | Tshepp | Cosmetics and Lighting Modification Discussions | 11 | 05-07-2011 08:51 AM |
DIY - 2010/11 Camaro AAC LED Side Markers Install with Turn Signals | GearHeadPeter | Camaro DIY & HOW-TO instructions & discussions | 0 | 03-03-2011 01:30 PM |
oracle h13 bulbs | steallife904 | Cosmetics and Lighting Modification Discussions | 2 | 08-21-2010 10:15 PM |
