11-09-2012, 08:46 PM | #1 |
OFF THE CHAIN
P0335 Crankshaft Position Sensor Issues?
Need help, Crankshaft position sensor code came on after a real hard start tonight, runs like crap and the traction control light is on, code is P0335 for Crankshaft position sensor. Anyone have a clue as to what this could be?
Any advice or suggestions as to what to look for? |
11-09-2012, 09:08 PM | #2 |
Being as you had an extended crank it's likely the Crankshaft Position Sensor is faulty or loose, which can also lead to poor drive-ability because the ECM can't reference a proper signal.
Circuit/System Verification
Note: You must perform the Circuit/System Verification before proceeding with Circuit/System Testing.
Note: You must perform the Circuit/System Testing before proceeding with Component Testing.
11-10-2012, 12:36 AM | #3 |
OFF THE CHAIN
Already went through every one of these steps before posting here, i think i got it narrowed down to something else but will post when fixed! Also my car is not a stock L99, i have many mods, cammed, forged, LS3 Conversion, ported heads, Supercharger.
11-10-2012, 08:31 AM | #4 |
Good luck, I'm interested to know what you find!
11-10-2012, 06:05 PM | #5 | |
I had read on another thread that a guy replaced the battery and it went away. I don't drive my vehicle very much and my battery was now two years old. I don't think with my driving habits that the battery was getting a full charge. If the battery is not fully charged, it's going to have problems starting up all the systems this car requires. When the issue was happening with me, it would begin when I started the car. It would take a few cranks to kick over and then after I hit the road, the stabilitrac would light up and the engine seemed like it was missing. I replaced the battery 3 weeks ago and I haven't had any issues since and I've been driving the hell out of it. (It was happening once a month so I've got some more miles to put on it before I can say the replacing of the battery is the true fix). |
