07-20-2012, 09:02 AM | #1 |
Steering leaning left - cause: new sway bars or wheels??
The other morning I noticed that my steering was off-center (had to keep the wheel turned to the left a bit in order to drive straight)... I hadn't noticed when it started happening, but I do know that it was driving straight last week.
I'm not sure what the cause could be. Any ideas? Recent changes to the car are: - I had installed Pfadt sport sway bars about 3 weeks ago. Steering was okay for 2 weeks afterwards. The other night I decided to put lock-tite on the rear bar bolts because I noticed that they were loosening. This was done the night before I noticed the steering off center... but would adjustment of the rear bar affect the steering straightness? - I had recently (within ~2.5 weeks ago) put replacement wheels/tires that I bought from a forum member. The same 20" stockers, just with newer tires with more tread. Maybe the wheels needed to be rebalanced? - About 2 nights ago I took a 90% right turn too sharp and slammed the right rear wheel into the curb. The wheel now has some deep road rash. Think the wheel may have been tweaked somehow to affect the steering? It doesn't look off on visual inspection. Anyway, I'm just wondering what everyone's thoughts were on what I should do first to correct this. I'm thinking of first trying a wheel balancing, then if that doesn't work, getting an alignment. If those don't work, then I was thinking of springing for the Pfadt endlinks (I have the stock endlinks on there now).
Self-installed all mods with help from Camaro5 forums! HUD, Front & Rear View Cameras, VMax Ported Throttle Body, Vararam Intake, VMax Black ICE-olater, Eibach Front Sway Bar, Extended Vinyl Stripes
07-20-2012, 10:17 AM | #2 |
Drives: 2011 2SS/RS M6 VR Join Date: Aug 2011
There's your problem. Alignment is probably off. Try another wheel but I would bet that's not the problem.
07-20-2012, 11:43 AM | #3 |
Yeah, I actually tried swapping with another spare wheel/tire I had last night, and the problem's still there. So hopefully going to get the alignment fixed will do it. I'll do that first then.
07-20-2012, 11:53 AM | #4 | |
Drives: 2010 Camaro, 2006 Z06 Join Date: Feb 2009
Get the alignment taken care of and go have some more fun! |
07-20-2012, 02:19 PM | #5 |
Thanks for the tips, everyone. I went to get the car realigned during my lunch break and it drives straight and true again. Turns out the right-rear strut was very slightly bent from that curb hit. The alignment folks were able to compensate for it by adjusting some other connections, and realigning the rear and front. $175, but money well spent to fix this. I'll watch out for those curbs much more closely, that's for sure!
Oh, and I hope that I didn't imply that Pfadt sways were the cause with the thread title. I was just clueless about diagnosing this issue and it just so happens I recently installed the bars... which, by the way, have become just about my favorite upgrade to the car. And seeing how you guys at Pfadt look out for people on the forums, I would say sport sways are one of the best value for money upgrades.
07-20-2012, 09:17 PM | #6 | |
Drives: Camaro Justice Join Date: Jun 2007
A bent arm will not articulate as designed. The bent arm will create uneven loads most likely causing a failure from flexing at the bend. A lateral impact would most likely result in a bent toe link. Please double check with the alignment shop to see what was bent. |
07-25-2012, 09:22 AM | #7 | |
corner barstool sitter
Drives: 08 Mustang GT, 19 WRX Join Date: Jul 2012
If it's anything like the steering knuckle on a double-A-arm front suspension such as what's on the Corvettes or the 4th Gen F-bodies it is entirely possible for it to have bent without damaging the control arm. Norm |
07-25-2012, 09:54 AM | #8 | |
They made the needed adjustments to the RR area as well as the rest of the alignment to compensate, and the car drives just fine again, no issues.
