Old 11-24-2013, 10:12 AM   #1
steph09
steph09's Avatar
Drives: 2012 Camaro 2SS/RS L99
Help Aux Port
Is it possible to connect an aftermarket radio that has its aux input in the back to connect it to the center console area that has the built in aux jack so I can keep using the aux jack that is inside the center console?
Hope this question makes sense. Thanks in advanced.
2012 2SS L99 Build Date: 05/03/2012
steph09 is offline   Reply With Quote
Old 11-24-2013, 10:53 AM   #2
jd10013
Drives: 2012 camaro
I don't see why not. but keep in mind, replacing the head unit is a very expensive proposition. the bluetooth, steering wheel mounted controls, and even the temperature/blower/selector controls are all built into the head unit. if you want to maintain functionality of everything your going to need several additional components.
jd10013 is offline   Reply With Quote
Old 11-24-2013, 11:54 AM   #3
steph09
steph09's Avatar
My sister's camaro was done and had everything replaced speakers and headunit. Everything is still there with the metra kit. Blue tooth is built into the receiver. Steering wheel controls still work as well for volume. I was just wondering if i'll be able to retain the center console aux jack
