04-06-2015, 05:22 PM | #1 |
Oil change for ZL1
Hi guys,
I recently bought a 2013 zl1 vert. I took it to get the first oil change at the dealership. I asked for synthetic and they gave me semi-synthetic. Is this ok? I asked the service guy if that is ok since I was under the impression that it took synthetic. He said the car is made to take the semi-synthetic. Thanks! |
04-06-2015, 05:26 PM | #2 |
KaBoom1701
5-30 Mobile full synthetic
Mods:
04-06-2015, 05:29 PM | #3 |
Ok it was 5-30 mobile semi-synthetic
04-06-2015, 05:41 PM | #4 |
Drives: 96 camaro Join Date: May 2009
then you should have gave them a semi-payment when they were done not full payment............lol
all kidding aside I would use full synthetic, |
04-06-2015, 05:47 PM | #5 |
Haha it was half the price. I said "I asked for full synthetic" ugh gonna take it back!
04-06-2015, 06:02 PM | #6 |
Drives: 2014 ZL1 Join Date: Jan 2015
Full synthetic
04-06-2015, 06:10 PM | #7 |
This car does not actually call for full syn. It is a 50/50 blend. I myself after the first two oil changes switched to full syn.
04-06-2015, 06:29 PM | #8 |
Drives: 2013 Triple Black ZL1 Vert M6 ECF Join Date: Mar 2011
IIRC my 2011 SS had Mobil 1 embossed right on the oil filler cap.
My 2013 ZL1 and my 2015 Malibu just require Dexros which is semi synthetic . I had quite the discussion with the service dept manager when I took the Malibu in for it's first oil change. I initially was going to go with Mobil 1. We argued back and forth, and he finally said he'd gladly take my money, but GM only asks for Dexros. I decided to settle on Dexros for the Malibu. For the ZL1, I always ask for Mobil 1 even though it doesn't need it, Deros would be fine. |
04-06-2015, 07:46 PM | #9 | |
Drives: 2014 ZL1 Join Date: Apr 2013
Just for clarity's sake, as this discussion has been on this and just about every high performance GM board, Dexos is an oil specification developed by GM. A lot of oils meet Dexos specification, including 5w-30 Mobil 1. GM calls for any Dexos certified oil (some are synthetic bends and many are full synthetics). The dealer will likely put the ACDelco Blend in as the house oil if they are not paid to use Mobil 1. People sometimes call that oil Dexos, because the Dexos logo is more prominent than on other oils. Interestingly enough, GM calls for Mobil 1 for track duty on the Corvettes and Z/28, but not for the Zl1. So, in theory, you should have full warranty coverage with any Dexos certified oil. The full list is at: http://www.centerforqa.com/gm/dexos2-brands |
04-06-2015, 08:26 PM | #10 | |
The bottom line is that GM only spec's a 'Dexos' type of oil, which is a semi-synthetic oil for both my Malibu and ZL1. The oil caps on both have Dexos on them, not the Mobil 1 label that my 2011 SS had. Mobil 1 is fine, just not required. |
07-06-2015, 03:53 PM | #11 |
Drives: 2015 ZL1 Convertible Automatic Join Date: Sep 2011
Just had the dealer do my first FREE oil change at 1500 miles. They used Mobil 1 ,GM approves it for the free first 2 year changes. You can do twice a year. Even though my filler cap says Dexos
07-06-2015, 05:49 PM | #12 |
Drives: 2014 RRM ZL1 M6 Join Date: Jul 2011
I just had the dealer do my first free oil change, they put in Mobil 1 at my request. I told them I could pay the price difference from Dexos but they didn't charge me.
07-08-2015, 09:59 AM | #13 |
Drives: 13 ZL1 SIM, 99 Z28 Black Join Date: Feb 2013
Some say it's better to use semi-synth for the first 10k or so.
2018 C7 Z06 - WGG, M7. / 2013 ZL1 - SIM, 6 spd, RotoFab CAI, Can. / 1999 Z28 - Black, 6 spd, K&N, Subframe. / More Fun Stuff - www.inlandspeed.com
07-08-2015, 10:10 AM | #14 |
Drives: 2014 ZL1 White Convertible Join Date: Aug 2013
Gm did a service update for the oil requirements on the Zl1, and they change it from requiring full synthetic to a semi synthetic to save money, because most dealers agreed to a 2 yr free oil change. When I went in for my last oil change I was shocked to see them try to pass of semi syn on me. Then they should me a piece of paper that listed the requirements for the Zl1, and if you look closely you could see it was an update (meaning they modified it from the original requirements. (they ended up giving me full synthetic).
