10-13-2011, 02:39 PM | #1 |
I'm going to start machine polishing!
I'm ready to make the jump, but not sure exactly what products I need. I have already (all Adams)
Great white drying towell, wash mit, etc... I'm OK on the wash and dry. I have a foam gun too. Clay Bar (Mother's Brand) 2x double plush microfiber towels Americana Paste Swirl and haze remover Revive Polish 1 gallon detail spray. Do I need to buy new polishes too? I don't see anyone using revive polish with the PC. --- I am here: http://maps.google.com/maps?ll=40.806909,-73.478411 - Sent from my iPhone using Tapatalk |
10-13-2011, 02:42 PM | #2 |
The enjoyment never ends
Drives: 2010 1LT/RS IOM #25223 Join Date: May 2009
You need to buy Fine Machine Polish. It is used with machine instead of Revive.
10-13-2011, 02:45 PM | #3 |
Ok. Now aren't there 2 swirl removers? What gives? Is that new? I don't remember that last time i looked.
--- I am here: http://maps.google.com/maps?ll=40.806399,-73.476735 - Sent from my iPhone using Tapatalk |
10-13-2011, 03:24 PM | #4 |
Yep. The sever swirl remover is a heavy compound. If your car is newer you probably won't need it. It never hurts to have it on hand though.
10-13-2011, 03:24 PM | #5 |
knows 2 facts about ducks
There is Swirl and Haze Remover (SHR) and Severe Swirl and Haze Remover (SSHR). The latter is only needed if the car is in REALLY bad shape.
10-13-2011, 05:06 PM | #6 |
Drives: The shiny ones. Join Date: Mar 2010
I'd say most people are gonna be able to get the desired result with just Swirl & Haze and Fine Machine... even if it takes 2 passes of SHR.
10-13-2011, 05:58 PM | #7 |
Drives: 2011 Camaro 2SS/RS Join Date: Apr 2011
I did my black Camaro last weekend using Adams and the Porter Cable 7424XP. I was trying to remove spider web scratches that were all over the car.
I was amazed at the results. They're gone! I used the Swirl and Haze Remover, then the Fine Machine Polish. I finished up with the Buttery Wax. To prep for this, I watched the videos on their site several times. I'd post pics, but all I have is a phone camera. Good luck with your project.
Red hood spears; Corsa cat-back exhaust; Roto-fab intake; Engine bay black/red theme; Black outs including both bowties, tail lights, tail light bezels, and side lamps; gill stripes; 35% window tints; Side SS badges; Hurst-equipped badge. |
10-13-2011, 07:43 PM | #8 |
Why does Adam's bundle all purpose cleaner with their polishing kits? What purpose does general purpose cleaner serve when polishing? I know to use detail spray as a primer.
Ok... So i think I need a PC (seen as low as $116 shipped), adams backing plate, $25 Swirls and haze remover PAD, (I already have the polish) $13 FMP $25 FMP pad. $13 looks like i can do it for ~$200 And I wish I could buy the PC from Adam's, but it would mean buying more product than I need if I did so. As I own Americana paste wax, I do not yet want to buy MSW and the appropriate pad. If anyone has any thoughts, or wants to talk me into a FLEX, I am here to listen and learn. Should I throw in a glaze? |
10-13-2011, 07:48 PM | #9 | |
Between passes with polish you should mist each panel with 1:1 IPA and wipe off. That removes any leftover oils or polish that is on the car. That way none of that is filling the scratches making you think you're done when you're not. The Machine Super Sealant (wax was the old name) will provide much better protection than will Americana. It's worth it if you want to stay all Adam's. You don't need a Flex for a brand new Camaro. The PC will do it, just a bit slower. The PC is safer too.
[B]
10-13-2011, 10:09 PM | #10 |
Last Saturday was my first time doing anything like this. I found it fairly easy to do, but took me all day.
I may have been doing something wrong, but I used the smaller pads as much as the larger pads. With all the lines and curves on our cars, just felt more comfortable with the small pads in tight spaces. I bought a set of both small and large pads. My sets came with the appropriate backing pads and also came with the APC.
10-13-2011, 10:23 PM | #11 |
it's mind bottling..
Drives: SGM Join Date: Apr 2011
were can i get the port cable alone ? and the 3 necessary pads of course
10-14-2011, 07:51 AM | #12 | |
Just a car guy
Drives: 2016 Durango R/T AWD Join Date: Oct 2011
You can try Autogeek if you are just looking for the PC 7424XP. There are Pads kits available with the PC if that is what you are looking for. For Pads, depending on how bad your car is, Get an Orange Pad, White Pad and a Grey Pad. I bought the Menzerna Ceramic Kit from Autogeek and so far, the results are very good IMHO. I'd also check with Adams to see if they have a small package kit for the PC7424XP with just a few pads, since they are a site sponsor. |
10-14-2011, 10:09 AM | #13 |
Drives: 2012 Camaro 2SS -- 02 Escalade Join Date: Apr 2011
10-14-2011, 10:43 AM | #14 |
Let's go Rangers!
Got mine from Amazon for 118 shipped.
Similar Threads | ||||
Remote Start doesn't seem to work | pennor | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 28 | 01-21-2018 10:30 PM |
Remote Start on Manual Transmission | Dentyneice | Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum | 51 | 02-11-2015 01:56 PM |
car alarm push start remote start | nokia | Audio / Visual / Electronics/ Gauges / Nav | 0 | 08-27-2011 02:24 PM |
New OnStar iPhone app coming soon - Remote Start, Door lock/unlock all included | nashstat | 5th Gen Camaro SS LS LT General Discussions | 210 | 03-08-2011 11:41 PM |
Rough Engine Start After Tune? | Tanner | Tuning / Diagnostics -- engine and transmission | 9 | 10-08-2009 12:25 PM |
