06-21-2009, 08:21 PM | #1 |
12-08-08 Arrived 06-02-09
Drives: 1967 Camaro Richmond5-speed Join Date: Jan 2009
Outside Temperature Sensor
Does anyone know where the outside Temp. sensor is located?
Ordered 2SS/RS IOM,12/08/08. Arrived at Dealer 06-02-09 Brought Home! 06-09-09 |
06-21-2009, 08:22 PM | #2 |
Drives: S10 283 V8,Jimmy 4wd 4dr bk/bk Join Date: Dec 2008
many GM vehicles have it located on the central support in front of the radiator
06-21-2009, 10:47 PM | #3 |
Drives: 2010 RJT LT/RS Join Date: Jun 2009
Ambient Air Temperature Sensor Replacement Callout Component Name Preliminary Procedure Remove Front Bumper Fascia Upper Support. Refer to Front Bumper Fascia Upper Support |
06-21-2009, 10:49 PM | #4 |
xTooltipElement
Service Information 2010 Chevrolet Camaro | Camaro Service Manual | Document ID: 2179376 -------------------------------------------------------------------------------- Front Bumper Fascia Upper Support Replacement Callout Component Name 1 Front Bumper Fascia Upper Support Push-In Retainer (Qty: 6) 2 Front Bumper Fascia Upper Support Bolt (Qty: 4) Caution: Refer to Fastener Caution in the Preface section. Tighten 10 N·m (89 lb in) 3 Front Bumper Fascia Upper Support Procedure Slide upward and rearward to clear hood primary latch. © 2009 General Motors Corporation. All rights reserved. |
06-21-2009, 10:50 PM | #5 |
sorry I can't post the drawings.
06-22-2009, 10:16 AM | #6 |
SoCal Mayhem
Drives: 2010 Camaro 1SS/RS Join Date: Aug 2008
You have access to the Camaro service manual?
06-22-2009, 11:16 AM | #7 |
Drives: Not a Camaro :( Join Date: May 2009
I had to replace mine on my Dodge Caliber. It was right up under the facia just in front of the bumper. Made me glad I had an OBDII reader. Part was $14 from the dealer and replaced it myself. Probably saved over $100. My advice would be to go get the part so you know what you are looking for and check under the facia. Should be there somewhere.
06-22-2009, 03:54 PM | #8 |
Snow White can be naughty
in layman's terms, generally 8-12" above the pavement, behind the front fascia. your readings should be 6-10 degrees above actual ambient air temp because of reflected road heat.
in my Crossfire, it was 4-6" off the concrete and always gave a reading that made it look like you were driving through the 4th level of hell during a Texas summer. |
06-22-2009, 10:20 PM | #9 |
06-22-2009, 10:23 PM | #10 |
Drives: 2011 challengerR/T , 2010 Ram R/T Join Date: Aug 2008
I hope is better that the one in my HHR,that one is always nuts.....
Similar Threads | ||||
Add tilt sensor to GM alarm? | patriotpa | Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum | 8 | 08-09-2009 06:38 PM |
o2 sensor | hd48 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 1 | 06-17-2009 10:35 AM |
Temperature Gauge quit working today | TopFuelTim | 4th Generation Camaros | 1 | 04-13-2009 04:27 PM |
Engine temperature guage | Silveradohdltz | 5th Gen Camaro SS LS LT General Discussions | 0 | 03-17-2009 10:37 PM |
HID temperature questions... | Evotion | 5th Gen Camaro SS LS LT General Discussions | 1 | 10-18-2008 11:12 PM |
