08-24-2013, 10:48 PM | #1 |
Drives: 2013 Victorty Red Camaro 2SS Join Date: Jun 2012
DRL/Fog Light Harness from Gen5DIY
Does anyone have the plug and play harness from Gen5? How about the one with the switch? Was thinking about getting one but them debated about wanting a switch to cut the DRLs off at night if I wanted too. How hard is install if you get the harness with the switch?
08-24-2013, 10:51 PM | #2 |
Retired from Car mfrs....
Drives: 2LT RS/HR-V Join Date: May 2013
I went the cheap way and bought the Gen5DIY Halo harness which is simple and makes them the "drl"s during the day.
Then cut the pos +power to the fogs, fuse it, and run it off the marker light. Now fogs are really fogs, and run with headlights and parking lights.. all for about $65 |
08-25-2013, 10:41 AM | #3 |
^Did so there is no need for a switch? Require soldering?
08-25-2013, 11:36 AM | #4 |
No soldering/switch ...use a wire tap for the power wire
Phasetek makes a $15 kit with everything - "hard wire DRL kit" |
08-27-2013, 12:46 PM | #5 |
Drives: 2011 1LT RS imperial blue camaro Join Date: Oct 2011
How many plug and Play harness would i need to do it on my 2011 LT/RS?
08-27-2013, 01:21 PM | #6 | |
what do you want to do with your lights? |
08-27-2013, 01:26 PM | #7 |
Drives: 2010 Join Date: May 2010
Message chevy24@Gen5diy. He will get your squared away.
I just ordered a custom harness from Gen5diy. Got it exactly how I wanted with just a few PMs with chevy24. |
08-27-2013, 01:45 PM | #8 |
08-27-2013, 01:49 PM | #9 | |
http://www.phastekperformance.com/20...light-drl1.htm |
08-27-2013, 01:56 PM | #10 | |
08-27-2013, 02:11 PM | #11 | |
the wire allows you to have either the (drls)fogs on with headlights or fogs on all the time... |
08-27-2013, 02:15 PM | #12 |
oh ok cool thanks for letting me know. I didnt know what to get so i will def get the one from phastek
