Old 09-28-2014, 09:38 PM   #1
SSBUSDRVR
SSBUSDRVR's Avatar
Drives: '11 2SS/RS IBM/BLK M6
Mast Black Label Heads Stock Intake vs Fast LSXr
Anyone run Mast 11* 256 Heads with Stock Intake Ported TB and switch to Fast102 102 TB? Results? Hearing there is not much of a gain where it counts switching when using the Mast Heads. Trying to decide to spend the $ or just stick with stock Intake on motor (416)
'11 IBM 2SS/RS Built and Tuned by Vengeance Racing Vengeance PCM
Vengeance Racing Mast Black Label LS7 Headed 416
ProCharger Stage II D1X Race ,Monster Triple,Alky Control Meth Inj, Forgestar F14 Drag Version and a bunch of other blah blah blah.838/688 at 12lbs Street Friendly
SSBUSDRVR is offline   Reply With Quote
Old 09-28-2014, 10:37 PM   #2
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
A stroked motor with great heads should be able to take advantage of the 102 intake and TB. As for how much, who knows. The problem is, that pair can cost $1500 or more. That means it's gonna have to make quite a bit of HP to make it worth the cost.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 09-28-2014, 10:43 PM   #3
402
Drives: Camaro
I have always seen gains from a fast 102 all the way back to bolt on ls1s to modded ls*. People will argue the cost/hp, but at the end of the day it is a way to gain power. Your setup you will see a increase.
402 is offline   Reply With Quote
Old 09-30-2014, 02:50 PM   #4
SSBUSDRVR
SSBUSDRVR's Avatar
Thanks for the replies.
Just confirmed from the Manufacturer themselves that they get negligable gains with the LS3. LS7/Intake TB is a different story.
Old 10-01-2014, 04:52 AM   #5
VADER SS L99
VADER SS L99's Avatar
Drives: 2013 A6 GT 5.0
A FAST intake on a bone stock to wild 97-00 LS1 is a great bang for your buck. A LS3? Not so much. His set up May or May not see a decent increase but the FAST 102 setup on a set of LS3 Black Label heads that sticks out in my mind was one that was done about 4-5 years ago where it was some MAST LS3 heads, a VVT stage 1 cam and a FAST 102 set up. It gained 4RWHP at peak and lost torque and HP throughout the power band. I'm sure on a stroker build with a big cam it would be different, how much? Who knows but I'm just saying that intake is not so good for every combination.
