Homepage Garage Wiki Register Social Groups Calendar Search Today's Posts Mark Forums Read
#Camaro6
Go Back   CAMARO6 > Technical Camaro Topics > Wheels | Tires -- Sponsored by The Tire Rack
BeckyD @ James Martin Chevy
Old 05-21-2017, 10:37 PM   #1
seanblurr
seanblurr's Avatar
Drives: ZL1 1LE
Mounted: 19x10.5/11 305 square MRR track wheels on 1LE
Well folks, here it finally is. These are MRR FS01 19x10.5 +14 and 19x11 +36 wheels with 305/30/19 NT01's. This is a track specific wheelset on my 1LE and will see very little street time. Even so, for a 10.5 +14 front wheel, the poke is a lot less than I thought it would have been. Some of you I'm sure will complain () but poke is a non-issue on the track and looks come second. I was jumping around with different wheel and tire ideas and was skeptical at first of running a square tire, but ultimately after my own testing on track, I felt a square setup would be superior to a staggered setup. Technically this is not a true square set up as the wheels are different, but my main goal was to get more tire up front and not necessarily the benefits of running square (rotations etc.) If needed, I will at least be able to swap tires at my local tire shop. I have yet to drive it on track, so this may or may not be the answer. We are in relatively new territory when it comes to finding the optimal track set up for these cars, and it's ultimately up to use to find what works best. So this is my first attempt. For those curious, I came to these offsets by way of trying to maintain the same, oem, inner strut clearance on the front. I decided to drop the rear to +36 to try and maintain some semblance of the stock track width. Special thanks to MRR wheels and PK Auto Design for being able to quickly make the wheel to my exact specs. Anyhow, here ya go.
seanblurr is offline   Reply With Quote
Old 05-21-2017, 10:44 PM   #2
Richard0nee
Richard0nee's Avatar
Drives: 2016 SS M6, NPP
Looks good and that is a pretty aggressive offset!
Let's see the pokes, I always wonder how it would look especially with 305's squared
Richard0nee is offline   Reply With Quote
Old 05-21-2017, 10:50 PM   #3
formoutofchaos
Drives: Camaro 2017 1LE
Very sinister looking ! Love it
formoutofchaos is offline   Reply With Quote
Old 05-22-2017, 12:21 AM   #4
MatthewAMEL
MatthewAMEL's Avatar
Drives: 2023 CT5 Blackwing
Originally Posted by seanblurr View Post
Well folks, here it finally is. These are MRR FS01 19x10.5 +14 and 19x11 +36 wheels with 305/30/19 NT01's. This is a track specific wheelset on my 1LE and will see very little street time. Even so, for a 10.5 +14 front wheel, the poke is a lot less than I thought it would have been. Some of you I'm sure will complain () but poke is a non-issue on the track and looks come second. I was jumping around with different wheel and tire ideas and was skeptical at first of running a square tire, but ultimately after my own testing on track I felt a square setup would be superior to a staggered setup. I have yet to drive it on track, so this may or may not be the answer. For those curious, I came to these offsets by way of trying to maintain the same, oem, inner strut clearance on the front. I decided to drop the rear to +36 to try and maintain some semblance of the stock track width. Special thanks to MRR wheels and PK Auto Design. Anyhow, here ya go.
NT01 is my favorite track tire.
I'm really interested in hearing your impressions after a few sessions.
While I am going to stick with OEM for Track, I would almost certainly duplicate your setup for RE71s for AutoX in 19".
I'm leading AS in my local region, but just 'that short' at the National Events.
Great job and they look great.
2017 HBM SS 1LE
Sold
2023 Wave Metallic
CT5-V Blackwing M6
MatthewAMEL is online now   Reply With Quote
Old 05-22-2017, 01:01 AM   #5
glamcem
glamcem's Avatar
Drives: '19 RivrsdBlu 1LE ('17 1LE HB sold)
It looks just perfect, glad the offset settings worked for you. This would be the ideal offsets for our cars with that size for sure.
I will also have the NT01s mounted soon (hopefully) as I am not that impressed with the Trofeo Rs (305 Sq setup). Mine will be pretty similar to yours except 325s in the rear
glamcem is offline   Reply With Quote
Old 05-22-2017, 02:58 AM   #6
evanescent03
evanescent03's Avatar
Drives: '19 SS 1LE/'19 Rubicon/'20 AT4
That looks awesome. How much camber are you sporting up front?
evanescent03 is offline   Reply With Quote
Old 05-22-2017, 03:43 AM   #7
aai
aai's Avatar
Drives: '17 SS/1LE/PDR
looks awesome, thanks for the pics!
PRAY ported MSD/TB : ROTOFAB/dry : DSX flex fuel : HPA Stage 3 : ARH catted long system/oem NPP : RSR harness bar : RSD : FSO1 : MPS4S 305F/325R
aai is offline   Reply With Quote
Old 05-22-2017, 07:04 AM   #8
Chub2000
Chub2000's Avatar
Drives: 2018 camaro zl1 , 2007 porsche GT3,
Looks great. Cant wait to hear your opinion on track performance.
Chub2000 is offline   Reply With Quote
Old 05-22-2017, 07:13 AM   #9
mbar
Drives: 2016 1SS
Looks fantastic!
1SS, Black, Black Wheels, A8, MRC, NPP
mbar is offline   Reply With Quote
Old 05-22-2017, 07:33 AM   #10
BradfordCamaro
SABIO
BradfordCamaro's Avatar
Drives: 2016 CAMARO 1SS
Looks good for a track set up.
It will do wonders for your paint job if you drive that on the street
I like the +36 on the back. Always thought the +43 was conservative.
Imho 11 on the back and 10.5in the front is not square.
You potentially change the characteristics of the tire using different wheels.
BradfordCamaro is offline   Reply With Quote
Old 05-22-2017, 07:34 AM   #11
JRL1LE
JRL1LE's Avatar
Drives: 2017 SS 1LE
Sean, looks awesome! Any rubbing on the front when turning?
JRL1LE is offline   Reply With Quote
Old 05-22-2017, 08:06 AM   #12
GearheadSS
GearheadSS's Avatar
Drives: 23 LT1/22 Colorado TB/69 Chevelle
Looks great!
GearheadSS is offline   Reply With Quote
Old 05-22-2017, 08:49 AM   #13
aai
aai's Avatar
2nd pic you posted is awesome, using it for wallpaper. Looking forward to more info! In comparison on stance with 19s..cant imagine it getting any better.
Old 05-22-2017, 09:17 AM   #14
tx6g1le
tx6g1le's Avatar
Drives: 2017 Camaro 1LE
Looks great man! Paul and PK know how to fit tires on cars, no doubt!
2017 Hyper Blue 1LE
tx6g1le is offline   Reply With Quote
