Old 11-25-2009, 07:28 PM   #113
JusticePete
JusticePete's Avatar
Drives: Camaro Justice
Originally Posted by fixxxer525 View Post
Hey JusticePete, question with Forgeline, I was told by forgeline I have to run a spacer in order for my wheels to fit the Camaro, the wheel size is 20x10.5 with 295/35/20 Nitto INVO. Due to the "reverse mount" of the 20x10.5 wheel, if I want to eleminate the spacers, I have to run 10" wide wheel. I know your Pedders Camaro run 19x10.5, did you have to add spacers? I'm gonna have to bite the bullet and sacrifice 1/2 inch just so I don't have deal with dumb spacers. By the way, I was (past tense) going to run 20x10.5 all the way around. The other option I was given is the step lip outter but thats not the look I'm after. Performance wise, yes the step lip would be better. But I'm also going after the look and the option of step lip outter would make it look "cheesy". If you don't have an answer, anyone? Trying to figure out this wheel and tire combo is a PITA and its becoming very fustrating.
Forgeline did a spectacular job with the fitment. My wheels do not use spacers.
To make sure I reply properly, tell me if you would be running a spacer in both the front and rear, just the front or rear?
Old 11-25-2009, 08:14 PM   #114
fixxxer525
Drives: 01S10,01CBR600,05Ducati, 10 2SS/RS
Send a message via ICQ to fixxxer525
I was informed that the fronts will need spacers not the rears. So now I'm utterly destroyed that I cannot run 10.5" up front but settled with the 10" wheel in the front. We are suppose to have a discussion with Forgeline monday on 10.5" fronts. But I'm ok with 10.5" in the rear and 10" in fronts and that was my original plans. I just have to run a staggerd wheel setup of 295 and 275. This wheel and tire combo is a nightmare and only slept 4 hours last nite trying to figure out why we need a spacer. Still makes no sense, since you can run a 19x10.5 and I cannot run 20x10.5 setup. Its hard to visualize, need to see a wheel in order to understand more clearly. Probably something simple.
fixxxer525 is offline   Reply With Quote
Old 11-25-2009, 08:58 PM   #115
Info@PeddersUSA.com
Info@PeddersUSA.com's Avatar
Drives: 5th Gen Rental
the offsets of the front are in fact different than the rear. There are no spacers on the Pedders Camaro. Both front and rear are 10.5 inch wheels.
mike
dms
Info@PeddersUSA.com is offline   Reply With Quote
Old 11-25-2009, 09:25 PM   #116
fixxxer525
I wonder why yours works and not mine. I'm gonna go out on a limb and say its due the 19" wheel instead of 20". Does it really make that much of a difference?
Old 12-02-2009, 01:42 PM   #117
JusticePete
I think it is a limitation of the thickness of the hub material. There just in't enough so a spacer is used to push the wheel out a bit.
Old 12-02-2009, 11:04 PM   #118
fixxxer525
I just got word on monday that they could do it and it was going to take an extra 2 weeks. I was like AWESOME. 2 weeks is nothing. Thanks for the info, though.
Old 12-02-2009, 11:06 PM   #119
JusticePete
Forgeline FTW
PEDDERS SUCCESSFULLY FITS 305s ON ALL 4 CORNERS! Info@PeddersUSA.com Suspension / Brakes / Chassis 467 06-11-2013 09:45 PM
New Camaro Exterior and Interior Stainless Steel Trim Parts from RPI Designs! RPI Designs Exterior Parts & Accessories 30 02-20-2013 03:23 PM
Pedders Suspension Benchmark Track Testing and New Jersey Track Day Info@PeddersUSA.com USA - NY / NJ / PA 35 10-26-2009 05:20 PM
Pedders partnering with GM Racing on Camaro suspension Info@PeddersUSA.com Wheels and Tires Talk Sponsored by The Tire Rack 6 09-30-2008 12:14 PM
