06-11-2016, 10:44 AM | #1 |
Recall
So I took my 2SS in this morning to get its first oil change. I also am going to have them check the seats. Motor are not working. I was told that there are two possible recalls. The first one has to do with the oil pan. If it the wrong one, he said that they will have to remove the motor to add something. He said that he has only done two. All the other cars had the correct pan. I hope mine has the correct one. The second one was for the rear coils. If they are the wrong ones, they will have to replace them. I am waiting to hear if I am part of the recall.
2016 Camaro 2SS "Black Widow" |
06-11-2016, 10:52 AM | #2 |
Drives: 2016 Camaro 1LT Join Date: Apr 2016
mychevrolet.com should tell you if you have a recall before you get a letter or the dealers even know.
Life after retirement |
06-11-2016, 11:09 AM | #3 |
yup, mine has the oil pick up tube recall
06-11-2016, 11:12 AM | #4 |
Drives: 2016 Black Camaro 2SS Join Date: May 2011
Hasn't this recall been in place for a while now like month or better? or is it something new that just came about?
06-11-2016, 12:06 PM | #5 |
Drives: 2SS, Hyper Blue Join Date: Feb 2016
Maybe, Maybe not. Many cars fell into the recall range, but not all had the bad pans. Easy to check. BTW, the engine does not come out...Parts below the pan are removed so it can be replaced..
If your dealer is pulling the engine to do this run away! http://www.camaro6.com/forums/showthread.php?t=447820 Also, never heard of the spring recall...I think he was referring to the rear toe links. Also easily verified as to whether or not you have the suspect parts..
Steve
Hyper Blue 2SS, 6M, NPP, Sunroof, Nav |
06-11-2016, 01:50 PM | #6 |
Nerd
Drives: 2016 Hyper Blue 2SS Join Date: Oct 2015
Yup and the forum even has a special section just to discuss recalls and tsb's.
Hyper Blue 2SS, 6M, MRC, NPP & Sunroof
06-11-2016, 04:36 PM | #7 |
Thanx that make me feel better. Also, this guy was just a service writer for the dealership.
06-11-2016, 05:17 PM | #8 |
Drives: ... Join Date: Jan 2008
Wow recall already?
06-13-2016, 01:21 PM | #9 |
Got the call today from my dealership. My car has all the updated parts it needs. The only thing they will have to order is something for the passenger seat. The motor is stuck and it will not roll forward nor recline.
06-13-2016, 02:04 PM | #10 | |
Drives: 2016 Camaro 2SS (on order) Join Date: Mar 2016
2016 Camaro 2SS Garnet Red
V8, Dual Exhaust, MRC, Nav, Sunroof, Loaded "Ahhh! Take care to get what you like or you will be forced to like what you get!" - Lyrics from a song from Scooter: "Apache Rock the Bottom!" Previously owned 1998 BMW 540 w/M-series package 1991 Trans Am GTA 1985 Saab 900 Turbo (Burned leaded fuel on the Autobahn) 1985 Firebird (R.I.P.) 1976 Camaro LT |
