11-18-2015, 08:37 PM | #1 |
Drives: '23 LT1 A10 Join Date: Oct 2015
Do headers require a tune?
Like topic says if adding headers do you need a tune? I have a brand new SS and am concerned about tuning due to it possibly voiding my power train warranty if deemed it was the cause. At least with headers I can remove them and stick the stock ones back one if need be.
24 LT1 M6 Sharkskin Metallic
11-18-2015, 08:38 PM | #2 |
Drives: 14 SS/ 1LE Join Date: Jun 2013
it has been asked and answered countless times
11-18-2015, 08:50 PM | #3 |
Drives: 2013 ZL1 Triple Black Vert M6 #5591 Join Date: May 2013
Need tune if you want to lose the check engine lite
695 RWHP / 660 RWTQ @ 13.5 PSI
Dyna-Tech Headers Ceramic Coated w/Super Flo Cats, JRE Custom Rough Idle Racing Cam Package and 125 RWHP Pulley Kit w/ 28% pulley, Custom Tune by Ted, ID850 injectors, JMS Fuel Booster, NGK Plugs, MSD Plug Wires, Roto-Fab CAI, Roto-Fab Big Gulp, Elite Catch Can, Mild to Wild, 90mm VMaxx Ported Throttle Body, Skip Shift Elim., D3 Coolant Resevoir, Separated Clutch Resevoir, and Fuzzy Red Dice.. |
11-18-2015, 08:54 PM | #4 |
Sorry. I primarily have to use my phone since my desktop has broke recently.
11-19-2015, 06:23 AM | #5 |
Started#gottalovethatblue
Shorty headers do not require a tune. Long tube headers do require a tune to remove the eventual check engine light. Certain high flow cats bolted to stock manifolds or shorty headers will not throw a check engine light and will not require a tune. However, to get the most out of your mods a tune is recommended. Otherwise you are leaving hp on the table.
11-19-2015, 07:39 AM | #6 | |
11-19-2015, 07:51 AM | #7 | |
11-19-2015, 08:20 AM | #8 |
Drives: 2018 ZL1 A10 Join Date: Sep 2014
I heard that the Diablo tune is almost transparent to the dealers, so if you're scared I'd go that route. Talk to JRE about it.
I agree with APEX - don't mod unless you want to void the warranty. It's my downfall with every vehicle I've ever purchased from a dealer lol.
SOLD! 9/1/2020 2018 ZL1 A10 Hyper Blue - Rotofab CAI, Gibson catback
@SurefireDetail OEM ZLE tails/third brake light, Gen5DIY reverse LEDs, front Amber LEDs, SMG laser LED side markers, SMG smoked reflectors 1994 Trans Am LM7/CPT 4L60E/9" 1987 IROC 2006 Silverado |
11-19-2015, 09:05 AM | #9 |
11-19-2015, 10:40 AM | #10 | |
Thanks guys |
11-19-2015, 10:45 AM | #11 |
Drives: 2011 SS (Sparrow Spearer???) Join Date: Aug 2013
before you swap gears out, make sure that you find a chevy dealer that will swap them and recalibrate your speedometer.
Black magic woman, don't turn your back on me baby!
11-19-2015, 10:48 AM | #12 |
Drives: 14 2SS RS and 16 Silverado LTZ Z71 Join Date: May 2014
I ran headers for a long time without a tune. I didn't tune my car till I got a cam.
11-19-2015, 11:14 AM | #13 | |
The "safe" answer however is like the others have already stated: If it would ruin your life in the event that something happened and you were stuck with the bill, I'd wait for those mods. All the best, Jared |
11-19-2015, 11:16 AM | #14 |
Drives: 1994 1LE / 2006 Z51 Corvette Join Date: Jul 2009
Headers, at least any good one, is going to change the flow through the engine and will effect the dynamics of how the engine runs.
That being said your factory computer can adjust fueling up and down about 25% from what it was written to give the car under part throttle conditions (not in PE mode). That being said (SES light conditions aside) you could drive the car around outside of WOT and the car can, for the most part, correct itself. Is it perfect, most certainly not but it isn't going to blow up on you. Now under WOT things are going to change. Depending on what the computer has been doing or how much you have changed the car yes things will change WOT and that is the main reason you should always have it tuned. Until they (GM) go to a lambda setup with WOT controls we always suggest tuning the car not only to make sure fueling is correct but you can generally tweak other settings to get the most from your modifications. |
