01-30-2016, 10:01 PM | #1 |
Drives: 2015 Camaro 2LT/RS Join Date: Dec 2015
V6 Sway Bar setup?
I have a 2015 RS and am looking to stiffen up the ride and hopefully eliminate the majority of the body roll and mushy feeling when cornering. Any suggestions on a good away bar setup for fairly cheap? thanks in advance
01-30-2016, 11:09 PM | #2 |
ITCRNRS
Drives: 2018 ZL1 1LE Join Date: Jun 2012
We ran 1LE sway bars front and rear on our V6 (without BREMBOS) and for $150ish per bar plus links its a great upgrade
2018 ZL1 1LE Ordered 6/29/17 Built 11/6/17 Delivered 12/7/17, Summit White, PDR, NAV, https://www.youtube.com/c/tylerpotter
SOLD: 2014 Summit White 1LE 2SS/RS, Recaros, NPP, NAV, KONI Yellow's SOLD: 2012 Black 2LT/RS, Fully 1LE swapped, Brembo swap |
01-31-2016, 10:25 PM | #3 |
Do you have the part numbers for the bars that are compatible w the V6?
01-31-2016, 10:39 PM | #4 |
Front Sway Bar (1LE) - 22812946
Rear Sway Bar (ZL1, 1LE) - 22786260 Rear Sway Bar Endlink (SS, ZL1, 1LE) (2) - 22761221 Front endlinks are the same as you have now
02-01-2016, 06:01 AM | #5 |
Drives: '13 2LT/RS Twin Turbo Join Date: Aug 2012
I run the ZL1 sway bars and they do great for me. I went ZL1 bars since I was staying staggered with my wheels. I'm sure there are better aftermarket bars but I don't race in the twisties so for me they are all I'll ever need. They definitely took care of all that body roll the V6 comes with.
3.6L Twin Turbo V6 Garrett GT28 turbos -- Jacfab forged connecting rods -- Diamond forged pistons(10.5:1) -- Alky Control Methonal Injection -- CircleD 2E triple disc torque converter -- BMR suspension 10.75 @ 131mph |
02-01-2016, 06:27 AM | #6 |
old school chevy rodder
Ask BMR..... talk to phastek..etc
02-01-2016, 09:28 AM | #7 |
KaBoom1701
Go with the ZL1 set up as you RS has a staggered wheel set up.
Or contact BMR or Apex or any one of our great C5 vendors here.
Mods:
02-01-2016, 12:22 PM | #8 |
ZL1 front bar #22842517
02-01-2016, 02:34 PM | #9 |
For anyone that has sway bars: Do you feel a difference in everyday driving? And how much weight do they add?
With great power comes with responsibility. However with great horsepower comes a hell of a lot of speeding tickets.
02-01-2016, 02:45 PM | #10 |
I have the 1LE bars and noticed a difference right away. They do weigh more but I don't think it is enough to think about.
02-01-2016, 07:00 PM | #11 |
I found both sway bars and links for like $260, seriously debating pulling the trigger on this. How much of a difference does it really make for those who are running the zl1 bars?
02-02-2016, 10:54 PM | #12 |
I run 2 catch cans...
I put a ZL1 front bar and end links on my 1LT, and the rear bar is stock. There is a S curve onramp near me that used to be squirrely at 30 MPH, but now I routinely take it at 55 without any body roll. The car corners like it is on rails now.
Overkill tuned • Air Scoop • CAI • VMAX PTB • JacFab Laminator FX + Extendolator • SOLO Hi-Flo Cats + Cat-Back Exhaust
View my top 3 LFX performance mods and more: . |
03-14-2016, 05:19 PM | #13 |
So this is a bolt on no other modifications needed?
03-15-2016, 11:13 AM | #14 |
Drives: 2012 Camaro RS 2LT 6spd man Join Date: Aug 2013
I have BMR 3way adj bars, Awesome for track use, now I just need to upgrade the struts. FE2 struts, are ok for about 15 min, they get hot then the car starts to push.
