05-13-2010, 01:50 PM | #1 |
Drives: 1st through 5th gen Camaros Join Date: Sep 2009
Camaro Vs Camaro
We thought we'd venture out of the suspension section and share some track numbers.
These are the analyzed results of our recent track testing: 3/4/2010 Hotchkis Track Day Test Stock 2010 Camaro vs. Hotchkis 2010 Camaro Hotchkis 2010 Camaro - 2010 Camaro SS - OE Pirelli Tires - 22109 Adjustable Sport Sway Bars - 25109 Adjustable End Links - 20104 Chassis Max Underbody Brace - 20109 Chassis Max Strut Tower Brace - 19110 Sport Coil Springs Streets of Willow: Data: Sectors: 1) – Hotchkis has a 4 mph advantage and 0.2 increase in lateral G 2) – Hotchkis has a 0.3 sec split time advantage 3) – Hotchkis shows more grip for off-camber turn compared to stock; Hotchkis has a faster entry & exit speed 4) – Tight right hander, no advantage 5) – Hotchkis has faster entry & exit speed and 0.3 increase in lateral G 6) – Hotchkis has a 0.3 sec split time advantage 7) – Even sector, no advantage 8) – Hotchkis entry speed is 6 mph faster and 0.3 increase in lateral G 9) – Even sector, no advantage 10)- Quicker transitions allow Hotchkis to carry 5 mph more exit speed 11)- Quicker transitions allow Hotchkis to carry 4 mph more entry speed 12)- Controllable throttle steering allows Hotchkis to exit 2 mph faster, engaging the straight-away earlier Skid Pad: Stock - 0.85g Hotchkis - 0.88g Hotchkis w/ Competition Bar - 0.91g 600’ Slalom: Stock – 67.1 mph Hothckis – 68.9 mph Hotchkis w/ Competition Bar – 69.2 mph Driving Impressions: In stock form, the 2010 Camaro is an understeering monster. Every turn demands so much from the front tires you can hear them scream. Pitch and Roll Transitions are slow, which make a heavy car feel even heavier. With the Hotchkis kit installed, the car is more balanced showing steady-state neutral steer with the ability to rotate the vehicle with control. With the added spring rate from the coils & sway bars, along with the chassis stiffening braces, transitions are quicker allowing the vehicle to turn, stop and accelerate faster. The car begins to feel lighter than it really is. Reduced roll angle allows the vehicle to change direction quicker and increases overall grip by using the tires more efficiently. |
05-13-2010, 02:17 PM | #2 |
Drives: 2010 2SS IOM L99 Join Date: Jan 2010
very nice.
05-13-2010, 03:36 PM | #3 |
cool
Similar Threads | ||||
GM unveils Jay Leno Camaro, Camaro Synergy, Camaro Chroma, Camaro Dusk at SEMA | irocnroll | 5th Gen Camaro SS LS LT General Discussions | 101 | 02-27-2012 12:25 PM |
GM memo to dealers | Moose | 5th Gen Camaro SS LS LT General Discussions | 41 | 02-04-2010 07:33 PM |
Ambient lighting (ABL) - the FINAL update = LIMITED TO DOOR PANELS | CamaroScotty | 5th Gen Camaro SS LS LT General Discussions | 338 | 04-15-2009 05:33 PM |
Answeres to questions I have stumbled on | dieseldave24v | 5th Gen Camaro SS LS LT General Discussions | 13 | 02-23-2009 06:56 PM |
