Old 01-17-2016, 01:22 PM   #1
Hunt-man
Drives: 2015 Z28 + Piper Comanche
Oil change: Is it a pain in the &$$
Thinking about doing my own oil change I'm at 600 miles and I'd like some clean oil in there. Likely not going to change the filter.
It looks like a tough job to jack it and a messy job to drain it. Yes? No?
I found this good thread:
http://www.camaro5.com/forums/showth...ght=Oil+change
How much is a change at the dealer? Now I'm thinking I'll pay to have it done....
Hunt-man is offline   Reply With Quote
Old 01-17-2016, 01:35 PM   #2
Zslash28
Jumanji
Zslash28's Avatar
Drives: '14 Z/28 - AGM - No A/C
You should still qualify for the free oil changes, no? 3 free within the first year IIRC.
No way in heck Id change the oil from my back. Thats just me. I have access to lifts on base and its like $5 for an hour. The only hard part is spending the money for 10 qrts of oil.
IMO the ZL1 add-on lift mount pads are a must before sticking the car on a 4 point lift. After its in the air, removing the underbelly cover drop the filter and two oil pan bolts. Could have it done in well under an hour.
If your going to the dealer, make sure they dont use a drive on/off platform lift, ive seen 2 Z's with damaged spoilers having been on this type of lift.
Zslash28 is offline   Reply With Quote
Old 01-17-2016, 01:57 PM   #3
Hunt-man
I don't have access to a lift so I'd be on my back.
I do have free oil changes but didn't want to blow one for an early oil change. I'd like my break in to have very clean oil.
Old 01-17-2016, 02:22 PM   #4
Ryanbabz71
Ryanbabz71's Avatar
Drives: 2018 Hyper Blue 1SS 1LE
It's pretty straight forward. Not messy at all. If you have ramps it's easier than jacking up
Ryan
Ryan
* 2018 1SS 1LE Camaro Hyper Blue Metallic
Car Build: http://www.camaro6.com/forums/showth...0#post10049680
Old 01-17-2016, 02:46 PM   #5
Hunt-man
I don't have ramps. Are they expensive?
Old 01-17-2016, 03:19 PM   #6
Zslash28
Jumanji
Zslash28's Avatar
http://www.amazon.com/Race-Ramps-RR-.../dp/B003WSZH9G
Old 01-17-2016, 05:04 PM   #7
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
not terrible...two drain plugs. The sump pan plug will drain only a quart or so, and the forward pan plug will drain the rest of the tank etc (9+qts). The oil filter has easy access and you always have to remove the belly pan and its associated bolts & two plastic rivets. Once the car is in the air, it isn't that bad. Make sure you have a drain pan with the capacity necessary. I think I have changed the oil 8-10 times due to engine work and track days. Consider getting a dimple magnetic drain plug for one or both plug positions.
'17 ZL1 A10 Mosaic Black PDR/Nav 2:03.08 VIR Full 11.003@129.2 1.75 (sold)
'15 Z/28 #325 Black a/c & stereo. 2:10.1 VIR Full (sold)
'12 ZL1 A6 Black 10.52@131 1.55 60' 2:13 VIR Full (sold)
Stephen12ZL1 is offline   Reply With Quote
Old 01-17-2016, 05:58 PM   #8
Ryanbabz71
Ryanbabz71's Avatar
Originally Posted by Zslash28 View Post
You can get less expensive versions also like rhino ramps
Ryan
Ryan
Old 01-17-2016, 06:16 PM   #9
Hunt-man
Thanks for the info. How often are you changing oil? More often if tracking?
Old 01-17-2016, 06:33 PM   #10
Schlok
Schlok's Avatar
Drives: 2015 Z/28 #397 2022 ZL1 #1799
I'm pretty sure the recommendations are change oil before and after track days but I'm not tracking my car currently.
Schlok is offline   Reply With Quote
Old 01-17-2016, 07:29 PM   #11
69L48Z27
69L48Z27's Avatar
Drives: 2015 Z/28; 1969 Camaro SS
I grew up in different school I guess. Always change the filter. What good is clean oil going through a dirty filter. Just me...
69L48Z27 is offline   Reply With Quote
Old 01-17-2016, 07:50 PM   #12
68camaroz28
68camaroz28's Avatar
Drives: 68 Z28, 69 Z28, 2015 Z28
X2!
I'd let the dealership change now (waste one as you call it) and then when they are used up then you change. But whatever you do, its best to change filter also.....
68, 69 & 2015 Z/28's
68 Z/28 Restoration Thread on Team Camaro
http://www.camaros.net/forums/showthread.php?t=182584
68camaroz28 is offline   Reply With Quote
Old 01-17-2016, 08:45 PM   #13
Z/28Dan
Z/28Dan's Avatar
Drives: 2013 HWSE Indy Festial #26
Let the dealer change it. Use up what you have included under warrantyand then worry about DIY changes.
Just my .02.
There are only so many days in your lifetime. So get out and drive your Camaro...
Dan
Z/28Dan is offline   Reply With Quote
Old 01-17-2016, 09:50 PM   #14
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Drives: 13' ZL1 Red M6
The oil filter is the worst part for my on the ZL1....not sure if it's the same configuration on the Z/28 though?
Mods:
