11-24-2010, 05:33 PM | #1 |
Drives: 2010 Camaro SS Join Date: May 2010
L99 Lifter TSB Questions, Any GM techs in here?
Is it better, is it more suited for rpm, is it able to withstand some of the newer AFM cams from Mast, Texas Speed and Comp. Mine are making the tick and I can have them replaced under warranty but if they'll be just as weak as the older L99 lifters then I will opt out and go right to a LS7 lifter.
Any GM techs in here to discuss these NEW L99 LIFTERS?
SOLD
2010 Camaro 1SS/A6 12.59@111.31 Magnaflow Magnapack Axleback & Resonated X-Pipe/OBX LT Headers/Airaid Cold Air Kit/Injection Connection Tuned |
11-27-2010, 03:21 PM | #2 |
Drives: 99 Camaro SS, 79 z28, 70 GTX Join Date: Oct 2009
a stock lifter is a stock lifter is a stock lifter.. its the material used in the construction (and of course design that makes a lifter hi performance)
LS7 lifters are no different, they wont solve anything long term if your having an issue now. A properly setup valve-train with correct PR length and spring install heights will cure most ailments but if you want a true hi performance lifter you switch to a Morel link bar( if they have an option for your application). |
11-28-2010, 09:47 PM | #3 |
Morals and adj valvetrain have nothing to do with a DOD lifter that is ticking, its a known problem and a TSB now...IN 08 GM USED A BETTER DOD LIFTER IN THE G8 AND THOSE GUYS COULD RUN CAMS WITHOUT ISSUES, THESE NEW LIFTERS ARE HAVING ISSUES...HENCE THE QUESTION....
SOLD
11-28-2010, 10:04 PM | #4 |
Drives: Granite Crystal Challenger SRT Join Date: Jan 2010
I purchased my Camaro 2/28/10 and had a lifter tick at 950 miles,they were replaced 2 weeks ago(5,551 miles) with the newly designed lifter.I have not had a tick since the replacement.
11-29-2010, 07:26 AM | #5 |
Drives: 67 goat, 69 goat ram air III Join Date: Mar 2009
There are redesigned lifters out now. See post 6 for TSB (Camaro is probably included by engine, 2011s should be ok??:
http://www.gm-trucks.com/forums/inde...owtopic=104679 Also reports of oil burners but not to many in the 6.2/6.0 |
Similar Threads | ||||
Stock L99 A6 Supercharger options, opinions, & experiences | 2010 Bumblebee | Forced Induction - V8 | 110 | 01-25-2019 04:23 PM |
some questions for a SC L99?? | wokkie | Forced Induction - V8 | 5 | 03-01-2010 02:20 AM |
New to cams, questions related to L99 | Longhorn SS | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 5 | 02-18-2010 02:50 PM |
2 SS RS L99 Tune Questions | Rockman | Camaro V6 LLT Engine, Exhaust, and Bolt-Ons | 2 | 09-20-2009 07:59 PM |
Questions about Tuning a L99 ? | Jekyll-N-Hyde | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 6 | 09-11-2009 12:00 PM |
