06-25-2011, 07:52 PM | #1 |
Drives: 2011 camaro ls Join Date: Feb 2011
2011 ls tire size
will a 245/35/20 all around be ok for an ls?
Injen short ram intake/ flowmaster 10series axle back/ muffler shop built 2.5" H pipe/ sony double din indash/ metra aftermarket kit/ rear bowtie delete/ custom gfx
06-25-2011, 10:18 PM | #2 |
Drives: 2013 VR ZL1 Manual Join Date: Jun 2011
If I remember right, the stock 20 inch tire size on the fron is 245-45-20 and the backs are 275-40-20. With that being said, Im sure a 245-35-20 will fit
2013 VR ZL1 Manual #0801. Airais CAI, More to come........
06-26-2011, 12:42 AM | #3 |
aka randers3
I wouldn't go any smaller than a 255/35/20 and you will need to do at least a 1 1/2" drop too make it look decent.
06-26-2011, 12:04 PM | #4 |
Drives: 2017 1SS Convertible Join Date: Feb 2010
If you want to know what the correct tire size is, you should look at the overall diameter of the tire which can vary slightly (.1-.2 inch) for the same size tire from manufacturer to manufacturer.
I believe all Camaro trims have an overall tire diameter of 28.6 inches. If you search on Tire Rack, you will be able to see the overall tire diameter for the particular tire you are looking at (look at the spec sheets for all sizes of a given tire brand/model). Smaller tires will simulate more aggressive gear ratios; but, you'll only see and feel gains when you get into tires that are 2-3 inches smaller than the stock diameter. The farther your overall diameter is from stock, the farther your speedometer and odometer will deviate. You would need a tune to fix it. If you search the Wheel and Tire forum, you should find a lot of helpful information about wheel and tires sizing, offsets and diameters.
Performance Mods: Injen Powerflow CAI, Doug Thorley Cat-Back Exhaust, Doug Thorley Shorty Headers, Trifecta Tune, TSW Nurburgring Wheels 20x9, 3.45 Ratio LSD Swap, VMax Black Ice-Olator
Appearance Mods: RiderGraphix LS7 Front Fascia Blackout Vinyl, Gill Insert Vinyl, Rear Deck Lid Vinyl (Gloss Black), Gary's Customs Painted Bowties Coming Soon: BMR Trailing Arms |
Similar Threads | ||||
* > * > * > * BLACK FRIDAY SALE STARTS NOW! * < * < * < * | CamaroScotty | Dealer Camaros for Sale | 8 | 11-26-2010 04:10 PM |
Think about this and the Z28 5th gen | 13F20 | Camaro ZL1 Forum - ZL1 Specific Topics | 41 | 09-04-2010 12:59 AM |
Bridgestone RE11 Performance Tire Review | Info@PeddersUSA.com | Suspension / Brakes / Chassis | 4 | 12-28-2009 10:58 PM |
Tire Monitoring System | monevz28 | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 7 | 11-22-2009 03:42 PM |
