Old 08-29-2009, 04:35 PM   #1
Ringo
Politically incorrect
Ringo's Avatar
Drives: 2SS/RS
The simple way to 500hp?
With my 2SS/RS on the horizon, I'm finding myself wondering what's the easiest way to get 75 or so more horse out of the LS3 and keep it simple. Shorty headers, CAI, and a performance tune will get at best 50 or so I'll bet. Leaving another 25 or so to go. Opinions? Dyno results? Buehler?
2SS/RS M6 IO interior. Built 8/14/09. Delivered 9/9/09.
Ringo is offline   Reply With Quote
Old 08-29-2009, 04:54 PM   #2
T D C
T D C's Avatar
Drives: hurst m6 V8 BLK 2SS vin 375
full headers with complete performance exhaust system , ECU reprograming ,and a performance air induction i think you will be very close to 500 horses
T D C is offline   Reply With Quote
Old 08-29-2009, 04:57 PM   #3
POWERFREAK
I.AM.
POWERFREAK's Avatar
Drives: 2011 2SS/RS/A6 cammed-n-whippled
go w/ LT headers (instead of shorties), CAI, tune, axleback exhaust...and there's an aftermarket pulley that added 10hp (see link below). All that would probably be around +75hp (at the crank anyway).
pulley install...
http://www.camaro5.com/forums/showth...pulley+install
NY5thgen.com
POWERFREAK is offline   Reply With Quote
Old 08-29-2009, 04:59 PM   #4
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
The quickest and easiest way, if you know how to do it, is nitrous probably... You'd probably better make sure you know what you're doing
If you're going for RWHP horsepower, though, I don't think you're going to get there with bolt-ons, including rockers and an LSXR intake manifold. You're going to need a cam, IMHO, to get there.
There are a bunch of choices though. It depends on your needs and $$$
'20 ZL1 Black "Fury"
Old 08-29-2009, 05:05 PM   #5
Sack Rat 2SS
Sack Rat 2SS's Avatar
Drives: Silver SS/RS, Man 6
Most of the HP references on most forums that I am aware of use RWHP, not flywheel. It can be confusing at times unless you are specific. So, with that said you are looking for about 63 rwhp on a LS-3 SS. Most bone stock LS-3's do about 355 rwhp for openers. Good luck. Fine looking Mustang in the pic.
Silver 2SS/RS Man/6
CTS-V front 6-Piston Calipers,
GM 3.91 Rear Gears
Sack Rat 2SS is offline   Reply With Quote
Old 08-29-2009, 05:12 PM   #6
Ringo
Ringo's Avatar
Drives: 2SS/RS
I shoud have specified that, I'm looking for 500 at the crank. With parasitic loss through the trans there's no way to get to 500 RWH without going into the engine. A 500 horse engine will suit me just fine. I'm happy with the 450 in my Mustang!
Old 08-30-2009, 11:36 AM   #7
Jason 98 TA
Drives: Camaro
500 is good, but 600 is better! We just finished a heads/cam combo that will mail order tuning makes over 600hp & drives awesome! Look for pics & info to be posted next week. The best part is the heads cam will use your heads as exchange so your probably talking about 1500 bux or so for heads cam that will add 100hp....
Jason 98 TA is offline   Reply With Quote
Old 08-30-2009, 11:41 AM   #8
Ringo
Ringo's Avatar
Drives: 2SS/RS
What about emissions? Can it pass?
Old 08-30-2009, 11:52 AM   #9
2010 CAMARO SS RS
2010 CAMARO SS RS's Avatar
Drives: 2010 Camaro SS RS
American Racing Long Tube headers and tune(50-60hp), New Era OTR ram air intake(20-30hp), and any axleback exhaust(10-20hp). thats 80-110hp!!
2010 CAMARO SS RS is offline   Reply With Quote
Old 08-31-2009, 08:43 PM   #10
IPS Brandon
IPS Brandon's Avatar
Drives: 2010 Camaro SS black
Send a message via AIM to IPS Brandon
Long tubes, X-pipe, CAI, 160 thermostat, FAST intake manifold, TB porting, and a Protune, and you will be nearly at your goals. It also depends on how your measuring your horsepower, we typically tell our clients rear wheel horsepower numbers you would expect to make on a chassis dyno, not brake horsepower numbers (many vendors use to over hype products)
Regards
-Brandon
IPS Brandon is offline   Reply With Quote
Old 08-31-2009, 09:38 PM   #11
themossman
Apprehensive Optimist
themossman's Avatar
Drives: '10 SS/RS SIM
How are you measuring HP? I'm not at 500 rwhp..but estimated crank I'm over....
Car is for sale --->http://www.camaro5.com/forums/showthread.php?t=158486
Current Summary:
Engine:Phase One-(All work by Vengeance Racing): Custom Cam, AR Headers, ported throttle body, ported intake, custom tune, dual valve springs, hardened push rods, under drive pulley, thermostat, Vararam CAI, C5R timing chain, Melling oil pump catch can, breather, MagnaFlow Sport Axle Back
Suspension: Pfadt Sport Sway Bars, Pfadt drop springs
Other: MGW Shifter, Custom Paint
my build journal ---->http://camaro5.com/forums/showthread.php?t=30057
themossman is offline   Reply With Quote
Old 09-01-2009, 09:02 AM   #12
Jason 98 TA
Drives: Camaro
That's find of the math that manufacturers like you to follow but it's far from accurate. Most of the headers, intake & tune cars make 415rwhp. Baselines are typically about 365 or so. I think 50rwhp is pretty much what you'd expect to see from those mods honestly. 50hp from a few easy mods is awesome though!!
Old 09-01-2009, 09:12 AM   #13
CamaroSpike23
Truth Enforcer
CamaroSpike23's Avatar
nitrous...lol
I piss excellence
and fart awesomeness
Old 09-01-2009, 11:52 AM   #14
CGM2SSRS
susp.ban4life!
CGM2SSRS's Avatar
Drives: Raptor
Like others, I think the easiest and cheapest way to get there is by squirt. But looking at your stang, my guess is you don't cheat like that. It's all about how deep the pockets are? I too don't play with replacing pulley's to achieve a negligible gain. Although I will,"stack" bolt on's at the intake side. Like a vara intake. Porting the intake/throttle body and adding a spacer. I've already achieved 32RWH (410RWHP) from LT's with cats and an axle back exhaust. And a good safe tune alone. Waiting for the intake parts to add them. The dyno after all this is said and done is likely to end up with the OE HP numbers from GM. At the wheels,not the crank. Seat of the pants should bring it close to my EX 07 GT500.
Hey Ringo, what does that shaker badge read on the stang? (nice car)
CGM2SSRS is offline   Reply With Quote
2006 SALEEN MUSTANG OVER 500HP VERSUS NEW 2010 CAMARO 2SS jacsr2010ss USA - Mid-Atlantic 29 06-09-2009 01:56 PM
* Simple view/breakdown of the 4/1 price increase * CamaroScotty Camaro Price | Ordering | Tracking | Dealers Discussions 94 05-14-2009 03:57 PM
6.2L Raptor, 500hp Factory Truck. syr74 General Automotive + Other Cars Discussion 12 05-09-2009 06:20 PM
Help plain and simple wayneworld Camaro Price | Ordering | Tracking | Dealers Discussions 30 02-24-2009 05:31 PM
