12-20-2013, 11:46 PM | #1 |
LTC, USA
Drives: Hobbes - 2013 Camaro 2SS RS M6 Join Date: Sep 2013
Reconnecting negative battery cable, alarm goes off... any ideas?
So I need to take my car back to stock so I removed my CAI and race scoop. I disconnected the negative cable from the battery while doing this. Only thing electrical I touched during the work was the cables for the MAF and the windshield washer pump and all I did with those was disconnect and reconnect them. When I finished I went to reconnect the battery cable and the car alarm immediately starts honking. Was wondering if anyone has run into this or has any suggestions. It is the middle of the night right now so I can't really trouble shoot it without pissing off the neighbors. Going to wait until mid-morning to see if I can get the alarm shut off once I connect the cable... hoping for some experience or suggestions by then.
Thanks in advance! ~Rex
12-21-2013, 12:57 AM | #2 |
Drives: 2011 RJT Camaro LT2 RS auto shift Join Date: Dec 2011
My does that. After connecting the battery just disarm as normal.
Caddy
12-21-2013, 01:05 AM | #3 |
I believe mine did the same thing when I disconnected the battery and shut the trunk. Realizing I was unable to open the trunk, I popped the hood open and jumped the camaro with another battery. Thats when my alarm went off. I just hit the panic button to make it turn off.
2011 Camaro 2SS/RS, Circle D 3200, ADM Transmission Cooler, BTR Valvetrain, Cam Motion .621 .595 228/244 113+4, ARH 1 7/8 full exhaust, Cold Air Inductions, Katech C5R TC, Melling HV, BTR SLR lifters, Trunion Upgrade, LS2 Dampner, LS9 head gaskets, Bo White PTB, MM can, GFX, Subs, B&M Deep transmission pan,
Holley fuel rail, Proform valve covers, relocated coil packs |
12-21-2013, 01:37 AM | #4 |
Drives: ( . )( . ) Join Date: Feb 2010
Just press the unlock button
12-21-2013, 09:51 AM | #5 |
LTC, USA
Thanks, that is all it was. I have disconnected the battery before and not had that happen so it freaked me out a little... plus it was late and I did not want to disturb the neighbors.
~Rex
