03-09-2015, 01:40 PM | #1 |
"Track Tuner"
Drives: 2010 2 SS/RS LS3 Camaro Join Date: Nov 2014
T6060 Shifting Problems
I have been using Joe Gibbs oil now Called Driven Racing Oil (owned by Comp Cams) in my race engines for probably 8 to 10 years now. I owned my own Dyno for years & found that Joe Gibbs oil was developed to make Bearings, Lifters/Cams last much longer in NASCAR engines. It really does make a big difference on engine life. So when I bought my Daughter a Camaro SS with a T6060 Tremec in it. I was not very impressed with how it shifted. The car only had 10K miles on it & it felt that the synchronizers were very tight in the trans. It shifted hard when cold & got somewhat better when warmed up. Therefore, like most people I went to the forums for Camaro, Mustangs & Challengers & many people are having issues with this Trans. I wanted to get rid of the Cheap Havoline Dextron III that GM claims is a lifetime fluid on these Trans. Therefore, I called up my old buddy Lake Speed Jr. at JG/Driven Racing Oil & talked to him about their STF Synthetic Formula Synchromesh Transmission Fluid. He told me that the formula had special additives designed to solve these problems. So I swapped out the ATF for 4 Quarts of the Driven STF & took it for a drive. Totality different. I was amazed at how much a difference it made in smoothing out the shifts. I believe that it will continue to improve as I drive the car. I only drove it for about 5 Miles, but you could tell that it now had a superior lube in the trans. The only drawback which I think is small is this stuff is not easy to find. You can purchase it directly from Driven or I bought mine from JDP Motorsports in Utah. It does cost almost $20 a quart. I think it is well worth it.
Here is the Data:
Regards,
Scott MPD Racing MPDRacing.com |
03-10-2015, 12:45 PM | #2 |
"Track Tuner"
I drove the car a second time. Even cold the Trans shifts better than it did hot with the original ATF in it.
Regards,
03-10-2015, 12:51 PM | #3 |
Drives: 2010 2SS Join Date: Sep 2012
I tried amsoil since im a "dealer" and i get it super cheap and it did nothing. Ive tried every possible damn thing except tearing the tranny apart. Ill have to give this a go.
2010 2SS- 562whp/634wtq 12 psi on3 turbo 78mm magnum /w aem truboost, pat g cam, Kooks 3" catback, Factory Rep 41s with 285/315 20" michelin PSS, Snow Meth, Hex Hood Vents, ZL1 FP & ADM FPCM /w JMS BAP, ID 850s, DSS lvl 4 axles & aluminum 1 piece D/S, Total Pro BMR bushings, fe4 sways, toe rods & trailing arms, Prothane engine mounts, MGW shifter, eaton true trac, mantic 9000 clutch, idealg master cylinder, JDP clutch oil reservoir, ram clutch pedal adjust, Tick clutch & bleed lines, Dewitts Rad
03-13-2015, 09:57 AM | #4 |
"Track Tuner"
Unlike ATF for auto trans, Driven STF is made for a Trans with Synchronizers. I believe that is why it works better.
Regards,
03-13-2015, 10:54 AM | #5 |
I love Royal Purple also and have used it's stuff for a long time.
http://www.royalpurpleconsumer.com/p...mission-fluid/
Mods: BBK Intake, BBK LT's and High Flow Cats, Corsa Cat-back exhaust, Hurst short throw shifter, SLP skip-shift eliminator. 7/1/09 Placed order for IOM/IO int/ SS/RS 6M 9/26/09 Took delivery! |
03-31-2015, 09:22 PM | #6 |
"Catharine"
Drives: '11 2SS/RS LS-3 IOM/IO vert Join Date: Mar 2011
TR6060 hard shifting issues here too, especially second gear grind when cold. I have yet to change out the fluid, please keep us posted.
04-01-2015, 12:27 AM | #7 |
Vrrrm.
Drives: 2011 2SS/RS LS3 Join Date: Jun 2013
Pretty sure its just shitty transmission in our cars not suited for the power output, pretty upsetting because the engine is nice.
I don't hear any of this from the v6 guys.
04-01-2015, 08:44 AM | #8 | |
'69 Owned Since '79
Drives: '69 Z/28 LeMans Blue w/White Join Date: Oct 2008
The fluid being hyped in this thread is very over priced. Mobil 1 Synthetic ATF is HALF of that and still gets the job done. Seems like an unpaid advertisement if you ask me. Several less expensive alternatives that work better than the factory fill. |
04-01-2015, 12:35 PM | #9 |
Drives: 2010 Turbo LS3 Join Date: Dec 2009
What non-shitty trans would you have preferred? TR6060 is pretty popular in lots of high HP applications. Some much more powerful than stock LS3.
2010 SS - On3 kit with downpipe cutout, CTR 78/80, CompCam 239/251 620/632 122+4, E85, Z28 suspension and ZL1 diff with Outlaw axles. Gen6 ZL1/1LE brakes.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. ZL1 brakes. |
04-02-2015, 07:21 AM | #10 |
Vrrrm.
I'll take just about anything, the 6060 is terrible.just look into the 2nd gear grind issues or cold temp shifting the thing feels broken.
04-02-2015, 08:44 AM | #11 |
My GXP with the tr6060. Never had an issue. https://youtu.be/qDyBIi2z6Pw
04-02-2015, 08:47 AM | #12 |
My SS with the tr6060. Never had an issue.: https://youtu.be/pu74VddHFUs
04-02-2015, 08:51 AM | #13 |
I've read all about them, but never had the issue. You could always have Rockland Gear, RPM, Tick etc rebuild it with different synchros.
I have a ZF6 in my Silverado (used in Corvettes for a while) and it is way more of a beast than the 6060, but there are trade-offs that have to be made when you want at manual to handle 700HP. Not sure there are any better manuals for American cars than the 6060 since all the manufacturers are using it. In fact, I can't recall another instance where all of the Big Three were using essentially the same part for something.
04-02-2015, 01:57 PM | #14 |
Agreed.
