03-07-2023, 01:20 PM | #1 |
3rd Gen Camaro Aficionado
Drives: '14 Camaro RS/SS Convertible Join Date: Nov 2013
Oil Change Hassle
I assume we all do the same thing: You can only buy 5 quart jugs of oil, so we buy 2 then measure out 2 quarts to use in lawn mowers and pressure washers (or just throw it a way). Buying 3 individual quarts costs way more than the 5 quart jug and single quarts aren't always available. WTF don't they sell 1 gallon (4 quart) jugs of 5w-30 so we can just buy 2 and be done with it? They sell 1 gallon jugs of the oil for my Duramax, but it takes 10 quarts! So, I have to buy 3 of those and still throw 2 extra quarts away!
-Mike
'14 Camaro RS/2SS L99 convertible - wine country cruiser '13 GMC 3500 SLE CC Dually Duramax - tow pig '87 Camaro - 10 second drag car that runs 11s |
03-07-2023, 03:17 PM | #2 | |
Camaro #4
Drives: 2017-Hyper Blue Metallic-2LTmanual Join Date: Dec 2015
DON'T toss the "extra oil!" Find a use for it.
Don M
Supercharged LGX + 6 speed manual = FUN!! |
03-07-2023, 05:27 PM | #3 |
It don’t come easy.
Sounds absurd that you would “throw away” what you don’t use. Put it on a shelf and use it where you can.
Also an Amsoil user. 2 gallon jugs and Im all set.
03-08-2023, 06:14 AM | #4 |
waiting at the tree
Drives: SIM 2010 2SS/RS A6 Join Date: Apr 2013
4 oil changes and the 5th is basically free
2010 2SS/RS A6 ZL1 Rims
60ft 2.03 13.08 at 107.82 (4/28) 2009 Pontiac G8 3.6L the DD |
03-08-2023, 08:09 AM | #5 |
Drives: 2014 Camaro 1LT Join Date: Aug 2019
03-08-2023, 02:46 PM | #6 |
The BBOMG fill-in husband
Drives: 2015 2SS/RS 1LE AKA V1LE Join Date: Aug 2010
I buy 2 5qt jugs of mobil 1 and after all the old oil is drained I pour about 1.5qts of clean stuff through before putting the plug back in so it grabs any gunk on the way down and out
UPSTATE C5 MEMBER
03-08-2023, 03:27 PM | #7 |
Keep it for the next oil change.
'22 2SS | Wild Cherry Tintcoat | Design Package 3 | NPP | MRC | A10 | NAV | Ceramic Coating | Full Frontal PPF | New Hood and Side Stripes | Michelin PS AS 4
Range AFM Disabler | Mishimoto Catch Can | Diode Dynamics side markers | Cold Air Inductions CAI | LLoyd Velourtex front/trunk mats with Camaro SS logo ZL1addons Deluxe Rock Guards, Stealth Lift Pads, and Tow Hook | Escort MAXcam360c | Footwell Lighting | Banks gauges in ZZPerformance pillar pod | Paddle shifter extensions |
03-08-2023, 04:20 PM | #8 |
Give speed a chance
Drives: 2015 Camaro 2LS, 2015 Camaro Z/28 Join Date: Nov 2019
THIS! It's not wine or soda pop. It doesn't go bad once you open it. However, I am anal enough that I always put a "purchase date" on the jug or bottle so I use my older stock first.
03-08-2023, 05:06 PM | #9 |
Drives: Camaro 1LE Join Date: May 2018
Dumping brand new oil due to a minor inconvenience...amazing.
03-08-2023, 08:20 PM | #10 |
Drives: 2012 Camaro SS Join Date: Dec 2019
I use the old oil first then add the new. It doesn’t go bad sitting in the jug.
2012 Camaro 2SS/RS - CSP Custom Cam 232/240 .615/.615 113 +3, Texas speed CNC heads, FTI billet triple disc converter, K&N cai, Katech ported TB, GPI Ported/rod modded manifold, Texas speed 1 7/8 headers, HFC, Flowmaster 2 chambers with x pipe, Mishimoto CC, MSD wires, Roto fab washer relocation, tru cool 40k trans cooler, apex scoop, Pedders extreme coil overs and much more!!
03-09-2023, 06:23 AM | #11 | |
waiting at the tree
Right now I have Pennzoil that I got for $22.99 cdn which is $16.67 usd
03-09-2023, 08:42 AM | #12 |
03-09-2023, 09:16 AM | #13 |
Personally I don’t see much of a benefit to doing it. It drains out pretty much all of the oil and also any sediment when it’s pouring out with it. If you really wanted to do more I would just fill it up with a cheap filter and oil and drive it for a little bit then do an oil change with the good oil. But as long as you change the oil regularly I don’t see a need for any of this. I know everyone here usually changed their cars oil before they even have too. I do like every 1,000 miles but it’s not a daily. And the oil that comes out is barely darker than the stuff I put in.
03-09-2023, 11:52 PM | #14 |
Remember conventional oil(non synthetic) in oil cans and changing every 3k miles. If you threw oil away, dad or granddad would beat your ass!
Current worst oil was yesteryears best oil choice. The times have changed for the best. Key point: just change your oil frequently and all will be good. |
