Old 06-11-2017, 05:55 PM   #1
pbclax1
Drives: Car
New hood tweaks
Was hoping you guys can help out. Just put on a new carbon fiber hood from carbon creations. It fits pretty well but I need to do some minor tweaking that I can't seem to figure out. When looking from the side above the wheels the hood is taller than the fender. It almost looks like it curves. The back near the windshield is actually down below the fender while the front in relation to the bumper and fender is pretty flush. I've messed with it a good bit and can't seem to find the solution. Any tips?
pbclax1 is offline   Reply With Quote
Old 06-13-2017, 03:22 PM   #2
INFERNOSS/RS
It's very likely a production defect, probably not much you can do about it other remanufacturing what was likely an expensive piece. The Carbon Creations unit we installed on our Vette needed the entire hinge mounting location cut out and rebuilt in order to mount to the car. Unfortunately, It happens.
INFERNOSS/RS is offline   Reply With Quote
Old 06-15-2017, 09:19 PM   #3
ZX1truth
ZX1truth's Avatar
Drives: 2010 2SS/RS
This makes me glad I bought a great used ZL1 CF hood. Plug and play!
LME built LSX427 w/t all Callies internals| AGP 65/65 TT | Holley Sniper Intake | Brodix BR3/LME custom ported | LME custom cam | Pro EFI 112 ECU | ID-1700x | NGK BR7EF | AGP's-Fore Triple Fuel pump | Monster LT1-S Triple | ZL1 3.23 diff, CF driveshaft, ZL1 axles | Hurst Line Lock | MGW Retro Short Throw | Pfadt solid subframe mounts | Prothane Motor Mounts | Revshift Poly Trans insert | Ground Control camber/caster plates | Accelerated Racing Solutions tuned|
God is too good! I don't deserve it, but I sure will accept it!!!
ZX1truth is offline   Reply With Quote
Old 06-16-2017, 05:41 PM   #4
Extreme Dimensions
Extreme Dimensions's Avatar
Drives: 2016 1ss Camaro
we require professional installation by a custom bodyshop on all parts and it may be a simple adjustment issue or maybe bumpstop or the whole hood may need to be adjusted not sure but i would take it by a local shop to have them check it!
Andrew Bettridge
Account Manager
Extreme Dimensions
1-714-278-8000 EXT 17
andrew.bettridge@extremedimensions.com
Extreme Dimensions is offline   Reply With Quote
Old 06-16-2017, 06:20 PM   #5
pbclax1
Drives: Car
Been dealing with your very helpful customer service and we are working on figuring it out. The hood is not able to have the oem washer nozzles at the moment because of the clearance either.
Old 06-16-2017, 06:23 PM   #6
Extreme Dimensions
oh ok good to hear and i think andrew was helping you out the other day! he also has a 5th gen camaro !
Andrew Bettridge
Account Manager
Extreme Dimensions
Old 06-17-2017, 04:43 PM   #7
pbclax1
Drives: Car
Yep! The customer service is awesome!
Old 06-21-2017, 01:52 PM   #8
Extreme Dimensions
good to hear!
Andrew Bettridge
Account Manager
Extreme Dimensions
