06-22-2017, 08:41 PM | #1 |
2010 ss 2500-3000k rpm note sounds horrible... suggestions?
2010 ss camaro m6.. cai, udp, ngk plugs, 160 degree thermostat, 1 3/4" long tubes no cats, no resonators, 3 inch into a x pipe, into magnaflow and 4 inch tips. Why do i have a raspy fart can sounding exhaust note between 2500 and 3k rpm? Is it because I don't have the cats? I had absolutely no crack in my ls2 g to with the same setup. What's the deal? Is it the x pipe or the 1 3/4 headers? I'm lost I've changed the set up 3 times now with differemy mufflers and set ups but with no luck I can't get rid of it. It sounds like a card deck being shuffled after 3k or a not so hard launch it sounds great. But if I go wot it sounds like shit... help me out. Thanks
06-22-2017, 09:39 PM | #2 |
Drives: 2011 2SS Join Date: Mar 2015
Posted on your other thread on what I think it is
2011 SS L99
LSA Supercharger, BTR Stage 3 PDS Cam, Yank 3200SS, Weapon X Stage 2 intake, LSA Heads, Flex Fuel, Ported throttle body, Speed Engineering Headers, NOWEEDS, ZL1 fuel pump, DSX AUX Pump, ID-1050X injectors, 3” pipe to NPP mufflers, 3.91 gears |
