11-27-2010, 09:06 AM | #1 |
Drives: 2010 SS & 2008 C6 Join Date: Mar 2008
Crankcase breathers, needed or not? Ted? Andy? or others?
If you have a functioning PCV system w/ a catch can on your car do you really need a breather to vent to atmosphere on a blown car?
Please discuss.
2010 SS L99, 536rwhp 10.843@126.72. Whipple Supercharger stock pulley, ARH 1 7/8 longtubes w/ catted xpipe, magnaflow 3" mufflers, ADM Race CAI, 3:70 gears, lightweight wheels and nitto drag radials. Stock internal L99, stock converter.
Bolt on best before blower 12.22@113.29 w/ nothing but ARH headers, catted x-pipe, ADM CAI and a tune on stock Pzero`s! Other car 2008 C6 Ls3, z51, A6, Npp Exhaust, best bonestock pass 11.80@118.82, Number 2 on the Corvette Forums Bonestock fastest list.. |
11-27-2010, 09:28 AM | #2 | |
Any time we can have a Vacuum even a Slight one in the Crankcase Rings Seal Better, and Pistons Go Down Easier unleashing some extra HP. The REV Xtreme Catch Cans we are carrying are well thought out and designed specifically for 3 different applications, N/A, Centrifugal/turbo, or PD superchargers. So I am recommending them for all Applications. I personally Run a Vacuum Pump Set up on my Race Car to maintain 8 inches of Vacuum in the Crank Case at all times. An Open Breather Works Well for WOT, but you must eliminate any PCV system or you will be sucking in Unmetered Air in to the intake tract affecting the Tune during Vacuum situations. Ted.
www.jannettyracing.com
11-27-2010, 05:20 PM | #3 |
Drives: 2010 2SS/RS IBM Black Polished Join Date: Feb 2009
Ted can you identify all pvc systems and locations just to make certain I have eliminated all of them
418 Stroker, 621RWHP 648 lbs TORQUE Built by Laramie GM Auto Center Tuned by Nick at Mac Autosport. EForce SC, 2 3/4pulley,LPE dual fuel pump, JRE Twin fuel rail upgrade, posi clutch kit, RX oilcatch can and breather, Callies Compstar crankshaft and rods, Racing bearings, CP -13.8 race pistons, steel rings, Comp Cams X6 blower cam, Springs, HD timing chain and tensioner, Doug Thorley Tri Y LT headers, 89.7lb injectors, RPM rollbar, DSS1400 shafts, Simpson 5 pt harness, BMR Toe rods and trailing arms, led lights, RPM input and output shafts
11-28-2010, 06:08 AM | #4 |
Drives: 1999 Trans Am Join Date: Jul 2009
I agree with Ted. Pretty much check your current setup and moniter the oil in the catch can. I like pulling a vacuum under boost for ring seal.
11-28-2010, 09:00 AM | #5 |
Thanks guys, thats the direction I was leaning, just wanted confirmation.
11-28-2010, 11:11 AM | #6 |
Drives: 2010 IBM 2SS/RS Auto Join Date: Apr 2010
Check out the link below GMRULZ lots of good info on the subject
http://www.camaro5.com/forums/showthread.php?t=102582
Version I
Jannetty Racing 550 RWHP Street Brawler Package, Powered by TVS2300 Maggie http://www.camaro5.com/forums/showthread.php?t=100385 Version II 416ci stroker/4L80e 701rwhp 750rwtq build and tuned by SPI-Performance |
Similar Threads | ||||
OIL CATCH CANS | john468 | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 5 | 09-16-2010 02:02 PM |
Crankcase Breathers, do we need one? | Supercharged SS | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 3 | 08-14-2010 08:36 AM |
