Old 07-20-2014, 09:22 PM   #1
cadyshac
It's in the hole!
cadyshac's Avatar
Drives: '11 2SS L99 SGM, '18 2SS, M6, HWSE
Which Spark Plug???
Looking for some advice, I was talking to a local shop about a dyno tune and they said I should change my plugs. I don't have it in front of me but I seem to remember them saying NGK TR6? (but I could be wrong on that)
Anyway, my mods are just CAI, longtubes w/ off road connectors and NPP, no cats, no resonator. Do I need to change the plugs from what came in the car?
Thanks,
Cady
cadyshac is offline   Reply With Quote
Old 07-20-2014, 09:23 PM   #2
2012LS3VERT
Drives: 2012 2SSRS Vert, Black w/M6
Nope. Leave them stock.
2012LS3VERT is offline   Reply With Quote
Old 07-21-2014, 08:28 AM   #3
uniqueskillz
uniqueskillz's Avatar
Drives: ETMC built 700+hp Twin Turbo LS3
you're fine with the stock ones. Once you go boosted you'll need colder plugs
uniqueskillz is offline   Reply With Quote
Old 07-21-2014, 04:46 PM   #4
lbheat
Echale Gas [COTW 3/10/14]
lbheat's Avatar
Drives: 2010 Camaro SS/RS Supercharged
I have TR6 spark plugs...mesh pretty good with my supercharger
They are a cheap replacement, I would recommend changing them if you are high mileage already. I changed mines out at 85,000 I think. I operate under the mentallity of changing things out ahead of time before something happens.
Kenne Bell
502 rwhp/ 471 rwtq at 9psi (daily driver...for now)
Performance: Corsa catback, JRE Super Tensioner, dual pass heat exchanger, R1 slotted & Dimpled rotors cryogenically treated
Cosmetic: Giovanna kilis 22", zl1 mailslot bumper, Custom Emblem Pro Badge, painted calipers
lbheat is offline   Reply With Quote
Old 07-21-2014, 07:01 PM   #5
Iam Broke
PHAT B33
Iam Broke's Avatar
Drives: 2012 TF3 Camaro 2SS/RS M6
When you go boosted, switch to non projected tip plugs. BR6EF for moderate boost.
Iam Broke is offline   Reply With Quote
Old 07-21-2014, 08:57 PM   #6
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
At your power level and quite a bit further than you are, stock plugs are perfectly fine. You won't gain anything by going with different ones, other than possible issues. If you go FI or nitrous, you'll want to look into colder plugs.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 07-21-2014, 09:15 PM   #7
cadyshac
It's in the hole!
cadyshac's Avatar
Thanks guys, I have no further plans at this time and my plugs only have 18,000 on them so they are going to stay in.
