Old 10-10-2014, 03:47 PM   #1
johnjohn
johnjohn's Avatar
Drives: 2010 ss
install question about lingenfelter twin pump setup
has anybody installed this kit without droping the gas tank??? i no you can cut a hole under the back seat for the pump, but this kit comes with the 2nd sending unit
thanks john
johnjohn is offline   Reply With Quote
Old 10-10-2014, 04:28 PM   #2
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
Seeing as how you have to pull the old pump out and install the new one INSIDE the tank, it's impossible to get access to the top of the tank without dropping it or cutting the hole.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 10-10-2014, 07:11 PM   #3
johnjohn
johnjohn's Avatar
Drives: 2010 ss
i no you gota cut a hole man,,,, the kit has a 2nd sending unit,, so you cut two holes???? i dont wanta drop the tank if i ant got to...
Old 10-11-2014, 09:36 AM   #4
10aSSee D
10aSSee D's Avatar
Drives: Silver 2010 SS Camaro
I installed the ADM dual fuel pumps which are pretty much the same I think and I would just drop the tank so you can do the install and wiring right and then cut a hole for future use if you need to just swap pumps.
MODS:
Old 10-11-2014, 09:38 AM   #5
10aSSee D
10aSSee D's Avatar
Oh ya your car looks good, would love to see some pics if you have some to post.
MODS:
Old 10-11-2014, 10:10 AM   #6
johnjohn
johnjohn's Avatar
Drives: 2010 ss
thanks man i got pics in the camaro photos section
