05-26-2013, 01:27 PM | #1 |
HARD WORKING PATRIOT
Drives: 2011 CAMARO 2SS RS-AUTO Join Date: Oct 2010
omitted
05-26-2013, 05:13 PM | #2 |
Drives: 2011 1LT/RS A6 RJT SuperCharged Join Date: Mar 2011
Are you trying to remove "just" the wiper? So far it sounds like your trying to remove the entire arm. There is a little tab on the wiper, where the arm and wiper meet. Lift it up and the wiper should pivot and slide off the arm.
BMR sub frame brace, BMR tunnel brace, LSR sways, LSR CM ca & tl, Sphon ExD el, GM tower brace, Megan EZ Streets, Goodridge Stainless Steel Braided brake lines, PowerStop D/S rotors & pads, Doug Thorty Ceramic Shorties, Magnaflow x-pipe, MRT V2.0, KICKER PowerStage sub & amp, Infinity speakers & tweeters, Viteese Throttle Controller, Viteese Paddle Shifters, ACS T2 Splitter, ACS T2 Ports/Quad LED lights, VDI kit, Havoc diffuser, IPF ECU/TRANS tuned, IPF/KPE Supercharged. 364RWHP/297RWTQ |
05-28-2013, 10:35 PM | #3 |
Drives: 2012 Camaro SS 45th Convertible Join Date: May 2012
Arm
Just rock it back and forth and it will come off of the splines.
