07-07-2015, 07:24 AM | #1 |
Drives: Black 2012 ZL1 Join Date: Mar 2013
Balancer bolt ?
Is an ARP bolt recommended when swapping the balancer or will the GM bolt do? If ARP is the way to go where can I order just the bolt?
07-07-2015, 11:44 AM | #2 |
Go fast, please.
The GM bolt will work, just don't reuse the old one because it is a TTY bolt and you run the risk of it breaking...
With that being said, the ARP bolt seems to be the better buy.... I bought the ARP bolt from here: http://weaponxmotorsports.myshopify....ngine-234-2503 29.00 shipped. That was the cheapest I could find it. |
07-07-2015, 12:55 PM | #3 |
Drives: 2013 ZL1 A6 Join Date: Nov 2013
ARP is the way to go... You'll need a 1-1/16th 12-point socket, 250# torque wrench and a way to hold the crank from turning over if its an Automatic, manual you can use first gear and e-brake.
I bought mine from Ted @ Jannettyracing.com
07-07-2015, 10:35 PM | #4 |
Drives: 2015 ZL1 Coupe A6 & 2002 ZO6 Join Date: Apr 2014
I went with the ARP. Just installed my balancer this past weekend. It will need torqued to 235 ft lbs. I bought a 3/4" torque wrench from harbor freight. I also had a flywheel holding tool that i snagged on eBay.
2015 ZL1 A6 Coupe Crystal Red
ATI Balancer w/9.55 (22.5%) lower pulley, FIC1000 Injectors, Stainless Works 2" headers, Stainless Works Retro Cat-Back, V-Max Ported TB, Roto-Fab w/Big Gulp, Elite 2nd Gen Catch Can, Jannetty Tuned. 581 rwhp |
Thread Tools | |
