03-21-2012, 04:46 PM | #1 |
Engine cleaning
What can I use clean the grease under the hood?
03-21-2012, 04:49 PM | #2 |
Switchin' n Twitchin'
Drives: 2011 Camaro Join Date: Nov 2010
Grease can be cleaned with any general purpose cleaner...
I am not childish, you're just being a poopy head!
03-21-2012, 04:59 PM | #3 |
Drives: 2004 GTO Join Date: Feb 2012
I love using Simple Green because it's a very mild cleaner but does an amazing job. Spray it on and let it sit and bust loose all the grease and dirt and then take a brush to it and then I ususally start the motor up and take a hose to it and wash it all off then take an air hose and blow the excess off.
03-21-2012, 05:06 PM | #4 |
Camaro SL,UTs
Drives: 2010 Camaro SS/RS #16429 Join Date: Sep 2006
I make sure my engine is cool then I cover my air filter with a plastic bag and then just blast out the entire engine bay with water. Then I hit all with 50/50 Adam's All Purpose Cleaner and distilled water and let it sit there for about 5 mins. Then I take a brush and scrub it all down. Then rinse it all off. Then turn on the car and let it idle for about 15 mins. Then any exess I blast out with my master blaster and then wipe down any existing water with towels and then touch it all up with Adam's VRT and Adam's in and out spray.
03-21-2012, 05:33 PM | #5 | |
Drives: 2006 Pontiac GTO Join Date: Dec 2010
Engine bay looks sweet. |
03-21-2012, 05:35 PM | #6 |
Drives: The shiny ones. Join Date: Mar 2010
I need to give this video a refresh, but all the information is still relevant.
03-21-2012, 06:29 PM | #7 |
thanks! How often should I clean it?
03-21-2012, 06:51 PM | #8 |
As needed... when it looks dirty and just a wipe down with a towel and some waterless wash or detail spray won't do the job its time to do a full cleaning.
03-21-2012, 09:16 PM | #9 |
Drives: 1968 Coupe, 2010 2SS, 2011 2SS/RS Join Date: Oct 2011
Ssooch! Engine bay looks clean enough to eat off of. Nice work
03-21-2012, 09:26 PM | #10 | |
Davis
03-21-2012, 11:05 PM | #11 |
Building the Beast
ssooch, superrrrr clean....perfect
03-21-2012, 11:15 PM | #12 |
Camaro SL,UTs
Thanks Guys!!
03-26-2012, 11:51 AM | #13 |
Hey Guys, what would be the areas to protect (against water) with plastic bags in a stock engine?
Thanks for your help |
03-26-2012, 12:10 PM | #14 |
You can cover your alternator, not required, but couldn't hurt. Otherwise theres nothing to worry about on a stock engine. The biggest concern on any engine detail are open/exposed filter elements if it has them. Stock you have nothing like that to worry about.
Similar Threads | ||||
Roto-Fab | Engine Covers - S/C | Fuse Relay Cover | Radiator Cover | Billet Oil Cap+ | AutoAgenda | Exterior Parts & Accessories | 14 | 02-06-2013 08:43 PM |
Acronyms? | KEEP RT | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 20 | 03-11-2011 08:57 PM |
LS3 engine specifications | Tran | Wiki | 3 | 10-06-2010 10:56 PM |
LLT engine specifications | Tran | Wiki | 2 | 03-29-2010 10:06 AM |
Why i think you cant do a Dyno in the same day | 2SSRS@Gen5diy | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 123 | 10-22-2009 07:37 PM |
