06-06-2014, 09:52 AM | #1 |
Drives: 2013 SS Convertible Join Date: Feb 2014
Soft water or not
We have a water softener in our house and so 1 of our outdoor faucets is fed soft water, while the other is 'regular'. The regular water isn't extremely hard water, but hard enough that we wanted a water softener.
I am assuming that I should use the softened water while washing my Camaro, but wanted to get your opinions to be sure. Soft? Regular? Doesn't really matter? |
06-06-2014, 10:12 AM | #2 |
Drives: 2013 2LS BLK Join Date: Oct 2013
Soft will make water spots less likely, and easier to remove if they were to dry, So I would say if you had access to it use it.
06-06-2014, 04:06 PM | #3 |
Drives: 2014 Camaro 1LT/RS Join Date: Sep 2013
Soft.
Detailing is an involuntary obsession.
06-06-2014, 04:39 PM | #4 |
KaBoom1701
Use it if you can
Mods:
06-07-2014, 11:50 AM | #5 |
Like others have stated, Go 100% soft water... If you happen to have any dried spots or streaks later in the day after washing it, take a spray bottle filled with soft water and dampen a microfiber, then wipe the spots off, works perfect every time.
All of the black window trim and porous plastics will last much longer with soft water as well, versus using harder water which is harsher on them, spotting, etc. I wash all of my cars with soft water and they still look like the day I purchased them. Nothing like a clean Camaro out there on the road...
Roto-Fab CAI, #8 Fuse Pull, 1LE Emblems, misc cosmetic changes, and a mod list that is a mile long. |
06-09-2014, 02:31 PM | #6 |
Thanks so much for the input. It will be all soft, all the time.
06-09-2014, 03:09 PM | #7 |
Drives: 2014 Ford Focus ST Join Date: Jun 2009
Soft wash is the way to go, but remember to use less soap when washing the Camaro.....
06-09-2014, 07:26 PM | #8 |
Drives: 2012 2LT RS White Born: 11/10/11 Join Date: Nov 2011
Our water system, including softener, is located in the garage and I had a "soft" water line ran to the outside just to wash vehicles. Previously the outside only had a faucet that was fed the water system just after the main pump, meaning it was not softened. What a difference it made, especially on my other vehicles including a black Silverado.
*Grey Hockey Stripes; Heritage Grill; GM GFX - Unpainted Argent Gray; GM Dovetail Spoiler; Rivercity Creations custom painted rear bowtie, RS & Taillight Bezels; MRR M017 Graphite Wheels; Nitto NT555 G2; ACS 4Teen Heat Extractor
*RX Catch Can;CAI; MF Exhaust; VMAX CNC Spiral Ported TB; Overkill Stage 1 Supercharger System; Hotchkis Comp Sway Bar Set w/ End Links, Cadillac CTSV 4 Piston Brembos on all corners with SS Black Hat Rotors Youtube Channel - HPDE Driving Videos https://www.youtube.com/channel/UCpO...8aw6hgX3O1Uh7A |
06-09-2014, 08:58 PM | #9 | |
Sent from my HTC One using Tapatalk
[B]
06-13-2014, 06:07 PM | #10 | |
Drives: SUMMIT WHITE 2SS/RS CAMARO Join Date: Feb 2008
I guess that's true. This is after I had a water line added to my garage bay to keep my Camaro clean.......
07-06-2014, 11:13 AM | #11 |
Drives: 2013 2ss/rs Join Date: Dec 2012
Soft water cleans harder!
That's one if my company's tag lines |
07-06-2014, 12:18 PM | #12 |
Drives: 2017 Corvette Grand Sport 3LT Join Date: Oct 2010
soft water will suds up the soap better, so less is needed, or so says the soft water system seller...
I wonder too, less or no minerals in the water mean no included abrasives to scratch the clear coat - logically - right? Soft Water is def. a plus to avoid hard water spots if left to air dry. I hadda spend a good deal of time polishing my car recently 'cause the neighbor's industrial water sprinkler soaked my car, completely, while I was away and it dried in the hot sun before I could get to it. 2 coats of CGs Jet Seal 109 and a coat or two of wax didn't help protect it, btw. |
07-06-2014, 01:02 PM | #13 | |
07-06-2014, 01:53 PM | #14 | |
Drives: 2011 2SS/RS Victory Red Join Date: Aug 2011
http://www.purewaterproducts.com/garden-hose-filters Problem solved.
Updates: BTR Stage 2 VVT Cam Kit w/Smith Brothers Trunnions, Fluidampr, RX catch can, B&M Trans pan mod, Kooks Black Headers, Borla S-tunes, Eibach Multi-Pro-R2 coilovers and Swaybars, BMR Full Bushing kit with Toe and Trailing arms, RB Rotors w/EBC Pads, GForce 1400 Axles (now on order). AVH-X5800BHS in Scosche GM5201AB. |
