03-12-2011, 06:35 PM | #1 |
Drives: Aqua Blue 2SS/RS Join Date: Aug 2009
Newbie at the track
Here are the results from my runs at Mo-Kan dragway today. I'd appreciate any analysis that can be offered. Due to the wheelspin I was encountering, I was too chicken to disable all the nanny electronics. How much of a difference would disabling everything make? I only tried a roll into it and punch it launch since I assumed that the stabilitrack would just clamp down on a brake torque launch.
The next mods lined up are wider wheels and tires (315's) and coilovers. None of these times are corrected, just raw data Thanks for any constructive criticism. If it matters at last dyno was 373hp 393tq on ADM's dyno. |
03-12-2011, 08:14 PM | #2 |
Drives: 2010 Camaro 2SS/RS Join Date: Sep 2009
First off, good times for you mods and DA.
Looking at your 60ft times I will take it you have a manual tranny. The first advice would be get you some DR's so you can put the hammer down. While on the stock tires try rolling into the throttle a little faster to get your 60ft down. Lower the air in the rear tires and pump up the fronts to the max. The TC and Stabil will not bring your ET that much maybe a 10th. I just got back from a bracket racing event and my three runs were very consistent. 13.472, 13.460 & 13.441 so tomorrow I will make my dial-in 13.45 after making one run to check everything out. Have to work on my R/T though as I went -.064, .235 & .069.
2005 Dodge Ram 2500 RCSB Thunder Road Hemi Sport w/STS Turbo
2004 Dodge Ram SRT-10 - Silver - Stock 2003 Chevy 1500 RCSB Stepside 400SS - 408 in now awaiting Turbo |
03-12-2011, 08:52 PM | #3 |
My reaction times were hideous which is why I didn't add them to the chart. Car is an L99, btw, don't know if that makes things better or worse!
03-12-2011, 09:30 PM | #4 |
It's always GREAT seeing another ADM Racer!!! Good looking runs for a newbie...
Here is a couple of things that have helped me: 1. Are you rolling threw the water for your burnout? With street tires and even drag radials, you should go around the water and do a dry - short - burnout. 2. When leaving the starting line, you want to only give it as much throttle as you can WITHOUT spinning your tires and ease into WOT - In a fast kinda way - if that makes since. This is one of the hardest things to do, because your foot always wants to go strait to the floor...
03-12-2011, 09:42 PM | #5 |
Only drives on Sundays
Drives: '16 2SS A8 NPP MRC NGray Join Date: Feb 2011
Are you bracket racing? If so, keep doing what you're doing.
But if you want to improve your times, kill both TC and Stabilitrak and work from there. Since you say "brake torque" I'm assuming automatic. If so, rolling into it is your best option for traction and 60's until you get stickier tires. Good luck, nice report. Padre |
03-12-2011, 09:43 PM | #6 |
The lanes are very narrow at that strip, such that it's impossible to avoid hitting at least some of the water box. I'm sure that hurt as I couldn't get all the water off. And yes, I couldn't help planting the foot straight into the floor! I'll just have to be a little bit more controlled on the next trip.
03-14-2011, 03:01 PM | #7 |
Drives: 2010 camaro 2ss rs a6 Join Date: Oct 2009
Mokan
I was at Mokan the Sunday before with my 2010 Camaro bone stock on factory tires and my best passes were avoiding the water as much as possible and then doing a smokie burn out. Best 60' for that day was 1.93. With out getting the tires to smoke my best 60' was 2.09. Last year on a warmer track I had some 1.90s doing the smokie burnouts.
03-14-2011, 03:48 PM | #8 |
Drives: 2010 SS , 1970 Z-28, 2002 Avalanche Join Date: Aug 2009
OK rjsmith, I have an L99 with the same dyno numbers as you and have no problem hooking 1.8's in the 60 ft. time. I do have BMR track arms and toe rods but here is what I do, I pull around the water box, back up to the box till my rear tires are in it, hold the brake and press the throttle down till the tires start spinning. I will hold that RPM while spinning for a couple seconds (1001, 1002) and let off the brake and back out of the throttle. By the way, I have stock tires. I then pull up to the line making sure that I am in "the grove" when I stage in. I hold the brake and load the convertor by running the RPM up to 1800-2000. On the LAST yellow light I let off the brake and mash the throttle at the same time. I don't spin and I run the 1.8's with an average time of 12.7 @ 110 MPH. This was done in GA. at the C5 fest. Keep practicing and you will get good at your reaction times. Good luck and have fun!!!!
IF IT'S WORTH HAVING, IT'S WORTH WAITING FOR!!!! (AND IT WAS)
434RWHP/403RWTQ Livernois Motorsports 2C Cam kit Kooks 1 7/8 LT Headers/Hi-Flo Cats/Corsa Exhaust Roto-Fab CAI / Port Intake Precission 2400/2800 Converter/3.73 AAM gears Livernois Motorsports Tune Best time: 11.97 @ 117 MPH |
03-14-2011, 10:48 PM | #9 |
Writer
Drives: 2010 SS / 1967 Camaro Join Date: May 2009
If you are spinning on launch and threw the gears you have to change your strategy.
So you have an auto, and so I'd: -disable traction control -go around the water -two foot the brakes and gas -on the third yellow let off brake and squeeze the gas gradually. -if the car does not spin, get into the gas more quickly. I've typically run quicker with a little tire spin vs. a little bog. When I hit the gas gradually, I say out loud "Onnnnnnne."
PROJECT HEAVY CHEVY
Camaro Now: Mods for the Masses Part I | Part II 13.15@106 1.95 | 100% Stock 12.37@112 1.85 | + Kooks Headers/Cats + 20" 555R + CAI + BW TB + UDP + Tune 12.06@113 1.70 | + CD 3200 + 18" NT05R + RCR Intake + NE OTR + GPI Tune 11.84@115 1.59 | + 3.91s + Race Star 17x7 Fronts 10.90@125 1.47 | + GPI VVT Cam + BW Ported Heads + CD 3800 |
Thread Tools | |
Similar Threads | ||||
The Official Camaro5 Fest II Track Assault By Pfadt Race Engineering | PfadtRacing | Suspension / Chassis / Brakes | 466 | 09-16-2011 11:57 AM |
The Official Camaro5 Fest II Track Attack By Pfadt Race Engineering | PfadtRacing | Dragstrip and Launch Techniques Discussion | 3 | 12-19-2010 07:07 PM |
No. 6 Sunoco Camaro breaks track record at Mid-Ohio Road Course | Sean@Phastek | Camaro Motorsports Discussions | 24 | 06-23-2010 12:47 PM |
Get YOUR Driving on Track! Sebring International Raceway, May 22 & 23 | Apexer | USA - Southeast | 2 | 06-11-2010 01:09 PM |
Get YOUR Driving On Track! Texas World Speedway, March 27 & 28 | Apexer | USA - Texas | 4 | 04-03-2010 02:38 PM |
