05-15-2013, 10:08 PM | #1 |
How to remove RTV from headlight?
Long story short, I need to reopen my headlights. My friend used some RTV to seal them. Anybody know how to reopen the headlight? Do I just use a heat gun and take it apart normally?
I really need some help. Thanks.
|Trifecta Tune|Custom Magnaflow Exhaust|Cold Air Inductions C.A.I.|BBK LTs w/ HFC|Anvil Rear Notch Glossy CF Spoiler|Body Color Heritage Grille|10 spoke polished ZL1 replica wheels|VMAX ported TB|RS Headlights|Night Owl RGB Halos
05-16-2013, 03:14 PM | #2 |
Drives: 2012 Camero SS 45th anniversary Join Date: May 2012
I just did mine and no heat gun won't work cause you need the whole housing hot where a heat gun only will heat certain spot.. I put it in the over at 250 for 15 min and it peeled off like butter using a flat head slowly
05-16-2013, 08:15 PM | #3 |
Drives: 2010 Camaro 2LT VR/RS CGM Rally's Join Date: May 2009
yes just put it in the oven for around 15mins at 250-275
Email: rdurso1@yahoo.com |
05-17-2013, 12:09 AM | #4 |
Ok so for future reference to anybody that faces the same problem, I used the heat gun on the low setting (1000 Watts) and I was able to pry the headlight lens off. The tricky (most annoying part) is getting rid of the RTV. In order to do this, get a single blade razor and cut through it. It won't remove everything but it gets the job done.
I would've used the oven method had my friend not used crimps to tie the wires together. I don't own anything to remove and replace the crimps so a heat gun was used. Sent from my iPhone using Tapatalk 2
