Flowmaster Exhaust
Old 12-06-2013, 12:55 PM   #1
the barber
the barber's Avatar
Drives: 13' Sw 2ss Ls3
So Dealer Says...
Squeaky brakes on the ss are definitely normal and they squeak because they're brembo performance brakes and the ss is a performance car so u give up the quietness of regular brake pads for the performance and extra hp vs a v6.. go figure
the barber is offline   Reply With Quote
Old 12-06-2013, 01:40 PM   #2
BDBiker
BDBiker's Avatar
Drives: Black 2013 2SS/RS 1LE
No squeaking on my 1LE.
BDBiker is offline   Reply With Quote
Old 12-06-2013, 01:52 PM   #3
the barber
the barber's Avatar
I shoulda bought the 1LE lol im wondering if it could b reduced by the heavier wheel and tire combo assuming they weigh more...
Old 12-06-2013, 02:23 PM   #4
SS785
SS785's Avatar
Drives: Camaro SS
What they are telling you isn't true. My brembos don't squeak.
SS785 is offline   Reply With Quote
Old 12-06-2013, 02:59 PM   #5
patternpilot
patternpilot's Avatar
Drives: 2012 2SS/RS 05 Jag S type R
My brembo' don't make any noise and they should not make any noise. Try a different dealer.
There's more to life than gas mileage
LS3, Whipple, Custom Comp Cam, springs, pushrods, timing set, CAI intake, Apex cold air scoop, Doug Thorley TRI-Y headers, Billet Custom Products baffled Valve covers, Mighty Mouse Catch can, ADM FPCM, ZL1 fuel pump, MSD boost-a-pump, Hex Vent hood vents, ProSport gauges(fuel pressure, AFR, Boost), Corsa, No Cats. Jannetty remote tuned, Pfadt trailing arms, all parts user installed. No Dyno yet. Manual trans. 3.45 gears.
patternpilot is offline   Reply With Quote
Old 12-06-2013, 03:04 PM   #6
19car69
19car69's Avatar
Drives: 2012 1LS
I believe this could be moved to one of the dumbest things a dealer has told you thread. Don't listen to them, just find a dealer that wants to get it fixed and keep you happy.
2012 1LS, Cold Air Inductions CAI, Apex scoop, Apex water bottle relocation, VMax Ported TB, Vitesse Throttle Controller, BMR Sway bars, BMR 1.2" drop springs, Koni rear shocks, Elite catch can, Solo Performance V6 Mach X-LFX Cat-Back Exhaust, Hex Vents, 1LE strut tower brace, Barton short throw, separate clutch reservoir, American Racing TORQ THRUST M 18X9, HiTS radio with reverse camera, GM Blade Dovetail spoiler, 2010 leather wrap steering wheel, vented engine cover, added Homelink to overhead console.
19car69 is offline   Reply With Quote
Old 12-06-2013, 03:09 PM   #7
the barber
the barber's Avatar
This is what I was aiming at dumbest thing ive heard from these guys and still have stock setup with 9k miles and problem started a month after buying the car 1 year almost to the day ago
Old 12-06-2013, 04:25 PM   #8
tanur420
Drives: 2011 Camaro SS
They told me same thing. :/ eventually the squeak stopped...or maybe I dont notice it
tanur420 is offline   Reply With Quote
Old 12-06-2013, 05:10 PM   #9
Camaroshark
Drives: 2010 Camaro 2SS/RS RJT, 6speed
Early brembo's had this issue on the Camaro. There were weights they hung in there to try and solve the problem early on but then came the re-design pads that look like roller skates with the "harmonic dampers" that actually did solve the problem to a great degree.
2010 Camaro 2SS/RS, LS3 - 6 speed. Mods, Magnaflow exhaust with resonator delete. ******** 12" stealth box subwoofer kit, Kicker 400 mono amp, JL XD 400/4 amp.
Camaroshark is offline   Reply With Quote
