Old 12-07-2013, 11:08 PM   #1
enyce0387
enyce0387's Avatar
Drives: 2011 camaro 2ss/rs ls3
toe links
Looking to buy a set of the ZL1 toe links but all of the gm parts websites don't have an option to buy next to the links.... what gives?
enyce0387 is offline   Reply With Quote
Old 12-08-2013, 06:04 PM   #2
Ventmaster
Ventmaster's Avatar
Drives: 2017 1SS 6spd
Just call your local dealer and tell the parts dept. you're a regular customer and want the "jobber" (wholesale) price.
They're always negotiable and you might be surprised how reasonable they can be!
Old 12-08-2013, 07:10 PM   #3
ssmike
Missing Big Red
ssmike's Avatar
Drives: '13 Equinox CRT
I'm looking to upgrade my toe links also. How do the ZL1 links compare to Pfadt or BMR links? Do they have better bushings than stock SS links?
Old 12-08-2013, 08:46 PM   #4
enyce0387
enyce0387's Avatar
I can't remember I think it was pedders who said they were top notch. I guess i will be at my dealer this week.
http://www.camaro5.com/forums/showthread.php?t=212147
Old 12-09-2013, 12:44 PM   #5
Ventmaster
Ventmaster's Avatar
Exactly- Pedders doesn't make one. Justice Pete says GM Zl1 link is the way to go- nuff said.
Old 12-09-2013, 06:25 PM   #6
JDP Sales
JDP Sales's Avatar
Drives: Chevys at the limit
We still need to get them loaded on our website, but we do have a set in stock. They are identical to the stock toe rods, however they come with spherical bushings. They are a good option, but the arm itself is still prone to deflection in high HP applications.
Feel free to call, PM or email me anytime with questions.
Best regards,
Tyler
888-308-6007
Old 12-09-2013, 06:42 PM   #7
grocerygetter
instigator
grocerygetter's Avatar
ZL1 works great...Pfadt works better. Just my opinion of course.
-John S.
Thanks to:
Tony@ dv8motoring
TCAudio in Benton AR
Old 12-09-2013, 07:35 PM   #8
ssmike
Missing Big Red
ssmike's Avatar
Best regards,
Tyler
888-308-6007
Is there any advantage to the spherical over the poly bushings? I'm only going to be at about 475 RWHP some day with a cam so I'm not worried about too much power deflecting the stock arms. I've also been told that the stock toe links act as a "fuse" and will bend if in an accident or you curb it going too fast. It will protect the subframe from damage. The real issue with the OE links are the rubber bushings.
Old 12-10-2013, 11:43 AM   #9
Dexman1349
2010 2SS/RS M6
Dexman1349's Avatar
Drives: 2010 2SS/RS M6
I could tell you how the Pfadt toe links & trailing arms compare to the stock SS ones if they ever get shipped...
2/7/2014: 419 hp, 419 tq
Cosmetic: ZL1 front w/mailslot, painted stripes, powdercoated SS rims, tow hook, and full chrome delete
Suspension: Pfadt subframe bushings, Pfadt rear UCA bushings, Z28 Upper control arms, Spohn trailing arms with BMR trailing arm & differential bushings, ZL1 Toe Rods and springs, Prothane radius arm inserts & steering rack bushing, Pfadt Sport front sway, FE4 conversion w/ DS rear sway, Pfadt strut brace
Drivetrain: RMCR tune, CAI intake, Kooks headers, hi-flo cats & exhaust, VMAX TB, ZL1 fuel pump, LSR Tri-Ax shifter
Bumblebee Racecar Build
Dexman1349 is offline   Reply With Quote
Old 12-10-2013, 01:24 PM   #10
JDP Sales
JDP Sales's Avatar
Yes spherical bushings are better than a poly bushing, as polyurethane will still have some deflection. However the arm itself can deflect, so their are pros and cons to each.
We use the Spohn toe links w/Del-Sphere pivot joints on our JDP Camaro. The benefit of this option is you get the strength of an aftermarket arm along with the rigidity and free movement of the spherical joint.
Best regards,
Tyler
888-308-6007
