Gen5DIY
Old 12-09-2013, 07:40 PM   #1
Wilsonation
Wilsonation's Avatar
Drives: 2014 1SS 1LE
Wheel hop
2014 1LE on the factory G2s. I get what seems to me like a ridiculous amount of wheel hop. Anytime I hammer it and break traction, it just hops. Only time it won't is in first gear and I build the RPMs up to do a burnout. I thought it was normal until about an hour ago I had a guy come into work who has a '14 SS with the pirellis. He says he doesn't get any wheel hop at all. Is it because of the grippier tires I have and the bigger sway bar? Is this something I should get looked at?
I was hoping to get experience from both SS and SS 1LE owners. Please and thank you.
2014 1SS 1LE:
10/9/13 Ordered
10/16/13 Queued
10/28/13 TPW
11/2/13 Built and Bayed
11/7/13 Shipped
11/14/13 Brought home!
Wilsonation is offline   Reply With Quote
Old 12-09-2013, 07:51 PM   #2
Fraxum
Fraxum's Avatar
Drives: 2016 SS M6
First try trailing arms with new bushings. You can do the Trailing Arms + outer bushing yourself with a little patience. See my build thread. This worked for me. 1LEs have the ZL1 Toe rods, so no need to replace those.
If that doesn't do the trick replace the differential and rear cradle bushings.
To tighten up the steering do the Radius Rod Inserts, also in the build thread.
M6, Pray Ported TB and MSD, E85, LTs, cats, Rotofab Dry, BMR Trailing Arms
Old 12-09-2013, 07:55 PM   #3
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
Curing 5th Gen Camaro Wheel Hop
Old 12-09-2013, 08:11 PM   #4
Iam Broke
PHAT B33
Iam Broke's Avatar
Drives: 2012 TF3 Camaro 2SS/RS M6
Spherical bearing rear trailing arms and subframe connectors helped mine a lot. Pirelli's here though. Used to get a bunch, now none to speak of. Just smoke.
Iam Broke is offline   Reply With Quote
Old 12-09-2013, 08:26 PM   #5
Wilsonation
Hm. Thanks for the info guys! I just don't get it. Lol. It's completely stock. 1-3 will hop. I can see this being normal for a bolt on/tuned car, just thought it was abnormal for 100% stock. Thanks for the info though!
2014 1SS 1LE:
10/9/13 Ordered
10/16/13 Queued
10/28/13 TPW
11/7/13 Shipped
Old 12-09-2013, 08:45 PM   #6
Synner
Drives: not stock
Alignment may be off from the factory. Trailing arms (or just the bushings), cradle bushes, and alignment. Wheel hop will be gone for good.
Old 12-09-2013, 09:21 PM   #7
patternpilot
patternpilot's Avatar
Drives: 2012 2SS/RS 05 Jag S type R
I used to have wheel hop, but now I don't. I changed my trailing arms and that is all it took. Stock tire right now though.
There's more to life than gas mileage
LS3, Whipple, Custom Comp Cam, springs, pushrods, timing set, CAI intake, Apex cold air scoop, Doug Thorley TRI-Y headers, Billet Custom Products baffled Valve covers, Mighty Mouse Catch can, ADM FPCM, ZL1 fuel pump, MSD boost-a-pump, Hex Vent hood vents, ProSport gauges(fuel pressure, AFR, Boost), Corsa, No Cats. Jannetty remote tuned, Pfadt trailing arms, all parts user installed. No Dyno yet. Manual trans. 3.45 gears.
patternpilot is offline   Reply With Quote
Old 12-10-2013, 01:44 PM   #8
JDP Sales
JDP Sales's Avatar
Drives: Chevys at the limit
Stickier tires will exaggerated wheel hop further as there is more grip causing more force to deflect the stock rubber bushings.
I'd suggest looking into some trailing arms with outer T/A bushing (some don't include the outer bushing, so keep that in mind) Solid subframe mounts (I recommend Pfadt) and upper control arm bushings while you are in there. (we offer some pre-pressed in new GM brackets to save you time and labor)
These 3 things will cure wheel hop and give you a much more stable feeling at during high speed cornering. Feel free to call, PM or email me anytime with questions.
Best regards,
Tyler
888-308-6007
Old 12-10-2013, 02:06 PM   #9
Bo White
Bo White's Avatar
Drives: 2010 Summit White 1SS
I'm blown with a manual. Trailing arms and bushings, upper control arm bushings, cradle full bushings and toe rods installed and I'm hop free.
