Old 11-15-2011, 01:46 PM   #1
Rayban
Rayban
Drives: 2010 Camaro RS/SS IOM 6M
LS3 starter location?
Does anyone know where the starter bolts to the LS3 motor? Searched all over the internet but can not find an answer. I am installing an LS3 in a 1969 RS/SS. I have a 2010 Camaro and still don't see where the starter is bolted onto the block.
Rayban is offline   Reply With Quote
Old 11-15-2011, 01:51 PM   #2
13 ZL1
13 ZL1's Avatar
Drives: 2013 IOM ZL1
Below the passenger side exhaust manifold.
13 ZL1 is offline   Reply With Quote
Old 11-15-2011, 06:00 PM   #3
Caswell239
Caswell239's Avatar
Drives: 2011 2ss/rs
Thought it was driverside. See it from below..
Caswell239 is offline   Reply With Quote
Old 11-15-2011, 06:12 PM   #4
blake-b
blake-b's Avatar
Drives: 2009 ZR1
Definitely on the passenger at the bellhousing behind a heat shield.
Old 11-15-2011, 06:34 PM   #5
Madness11
086YN
Drives: Black 2SS/RS Demon of Madness
Yes I know where the starter bolts to.......your engine!!!! GET IT?!?!?!
Maybe somewhere under the car? Close to the transmission? Maybe even closer to the flywheel? Maybe its just one of seven wonders of the world? Maybe you should find an ancient Mayan person to help you locate your starter with a sun dial?
ORRRRR
You could go to autozone, buy a jack and jack stands, and return home to now jack your car up with the pretty new equipment you just purchased and play hide and seek!!!
Wait theres more....
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
Go back to autozone and buy a drop light because they tend to be very useful while working on and around a vehicle. Make sure you buy a good one. Cheap tools suck. But then thats all they offer at autozone....cheap stuff for high prices.....Snap On dealers rule.
Madness11 is offline   Reply With Quote
Old 11-15-2011, 06:37 PM   #6
blake-b
blake-b's Avatar
Drives: 2009 ZR1
Better than a drop light are those work lights on stands you can raise up and an accompanying one that sets on the ground. Lights up like the sun.
DIY: LS3 Camshaft Install (a lot of pictures, may take a moment to load) robertway Camaro DIY & HOW-TO instructions & discussions 313 12-16-2023 06:53 PM
iPhone/iPad tracking your location... Brokinarrow Off-topic Discussions 18 04-28-2011 06:58 AM
LS3 Specs revealed: GM's 436hp Sick 6.2L LS3 TAG UR IT Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 28 07-30-2009 06:02 PM
LS3 Specs, and Descriptions Mr. Wyndham Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 5 11-06-2007 01:04 PM
