Old 01-07-2012, 03:57 PM   #1
TornadoSS
WICKDSS
TornadoSS's Avatar
Drives: 2011 1SS/RS IOM LS3
Will 315's on rear require new alignment specs?
Sorry for the dumb question, I am lowered 1" with a great alignment now on stock wheels, tread wear is even all the way across on rears. I have F14 20x11 rear wheels coming and 315 tires, will I need different alignment specs? Thanks!
2011 IOM SS/RS, M6. Look up our all generation Camaro club website at Heartland Camaros
Gforce Engineering Drivetrain, ECS 1500 Supercharger, TSP Cam, Alky Controls Meth single nozzle. 91 octane, 698 RWHP 625 rwtq. 4200#+, Tuned by Justin "Justune" Kalwei
11.57 @ 126.8 mph with a crappy 1.80 60'.....still learning to drive....M&H DR's and skinnies on 17" Welds.
TornadoSS is offline   Reply With Quote
Old 01-07-2012, 04:07 PM   #2
UF4LIFE102SS
Treasure Coast Camaro 5
UF4LIFE102SS's Avatar
Drives: 2010 2 SS
U know we all like to answer. I would 2 b safe. I'm sure somebody will know more.
Old 01-07-2012, 07:12 PM   #3
Synner
Drives: cars
No.
Old 01-07-2012, 08:07 PM   #4
bkscott
bkscott's Avatar
Drives: 2010 Camaro 2SS/RS
Originally Posted by Synner View Post
No.
+1
94 Firebird Formula (Drowned 08/30/05)
2010 IBM 2SS/RS 6M Arrived 3/25/10.
ADM CAI, Borla Type S Cat Back, VMAX Ported TB, LG Short Throw Shifter, 1LE Shocks, Hotchkis Sway Bars, Whiteline Cradle Bushing Inserts, Custom Powdercoated ZL1's ,Michelin Pilot Supersports, Stainless Power Headers, Solo J Pipes, AAC LED Sidemarkers, ZL1 Rockers, SLP Splitter, ADM Stage II Cam,ZL1 Diffuser,Vitesse Throttle Controller.
bkscott is offline   Reply With Quote
Old 01-07-2012, 08:19 PM   #5
RaiderSS
RaiderSS's Avatar
Drives: 2010 Camaro SS2 DeadBLK
No alignment needed but this setup is only feasible when dragging... if you drive/corner aggressively or run road courses there is a high posibility of breaking the bead if u run factory rims because the even though it fits the 315 is too wide for the factory rear wheel.
RaiderSS is offline   Reply With Quote
Old 01-07-2012, 08:52 PM   #6
TornadoSS
WICKDSS
TornadoSS's Avatar
Thanks for the replies guys. I figured the alignment would be fine just checking to make sure. The 315's are going on 20x11 F14 rims, so no problems with bead.
Old 01-07-2012, 10:40 PM   #7
Camaro427
Drives: 2010 SS2 Camaro
315s on 11 inch wide wheels may have rubbing issues if the offsets are not correct.
I absolutely insist on anyone I do drop suspension systems to get an alignment. Camber and toe change a lot when dropping springs. Tires are too expensive not to get an alignment check
Camaro427 is offline   Reply With Quote
Old 01-08-2012, 09:19 AM   #8
mikepage0007
mikepage0007's Avatar
Drives: 2010 camaro
it appears that he is already lowered and aligned and is only changing wheel sizes..def agree, anyone dropping needs alignment...
mikepage0007 is offline   Reply With Quote
Old 01-08-2012, 08:37 PM   #9
Bruce@raymondsperformance
Bruce@raymondsperformance's Avatar
Drives: 2014 Z28 camaro
The alignment should be fine,but they may rub.we had to install some coil overs on one car that had drop springs and the tire and wheel set up due to rubbing.
Bruce@raymondsperformance is offline   Reply With Quote
Old 01-08-2012, 08:43 PM   #10
ParisTNDude
Owning SSes for 50 Years
ParisTNDude's Avatar
Drives: Sharkskin Grey LT1
The 315 35 20s are the same heighth as the factory stock 20s. The only thing that changes is the contact patch. I wouldn't think that would require a 4 wheel allignment.
The new ride: 2023 Camaro, LT1, Sharkskin Grey
Previous Performance Cars:
1966 Chevelle SS 4M, 2010 Corvette 6M
1968 Dodge Charger R/T Auto 2012 1SS 6M
1982 Corvette Auto 2010 1SS 6A
1984 Corvette Auto 2016 2SS 8A
1999 Camaro Auto 2017 HBM 1SS 1le
2002 C5 Corvette 6M 2018 2SS
2006 Corvette Auto 2023 Camaro LT1
ParisTNDude is offline   Reply With Quote
Old 01-08-2012, 08:57 PM   #11
TornadoSS
WICKDSS
TornadoSS's Avatar
Thanks for the replies and insight. The wheels are ordered with offsets specifically for drop spring Camaros. So far I have not heard of any rub issues with this wheel/tire combo with the correct offset numbers.
CAMARO WIKI Tran Wiki 66 04-22-2024 11:41 AM
JRE 3.73 rear end w/ posi installed.....questions Fiftydriver V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 4 04-17-2011 07:04 PM
who has the best bushings? VRMMMM Suspension / Brakes / Chassis 10 05-07-2010 06:11 PM
Putting down up to 50hp more at the wheels without engine mods Info@PeddersUSA.com Suspension / Brakes / Chassis 100 05-05-2010 03:48 PM
