02-11-2012, 02:01 PM | #1 |
movin' down the motorway
Drives: Summiit White 2SS/RS/M6 Join Date: Feb 2010
Which suspension parts to upgrade?
I'd like input regarding what suspension components I should consider replacing considering my goals below. I'll try to make this as painless as possible. Besides the mods in my sig, I'm having JRE install LPE 3:91 gears, axles, toe links, subframe bushings and trailing arms. Current RWHP is 463. I'm considering lowering the car a bit and I might add a power adder. No track or autocross. Purley a toy, but I want to build it "right". Thanks Mike
417 stroker - Florida Speed and Power
02-11-2012, 02:03 PM | #2 |
Drives: 89 IROC 350 Join Date: Mar 2009
So... what are you asking again?
If youre replacing "gears, axles, toe links, subframe bushings and trailing arms"... what else you you talking about? All that is really left is springs and sway and ABSOLUTELY replace those! I just got a one piece drive shaft. Can't wait to install it! |
02-11-2012, 02:09 PM | #3 |
Should I consider any other suspension parts considering what I want to do ? And I failed to mention, I'm not very knowledgeable regarding the effect increased HP has on stock suspension.
02-11-2012, 02:16 PM | #4 | |
The trailing arms and toe bars will help elimnate wheel hop. The upgraded dif should help with the spider gear failure problem. The subframe bushings will take out the play in the ass end of the car. Youre pretty much covered. A one piece driveshaft will help with throttle response. Springs and sways (with endlings and lower control arm reinforcing bracket) will help with cornering. Front radius rod inserts or bushings will help keep the front in check while cornbering. A short throw shifter (MGW is my favorite tho I have Hurst) is a MUST. With added power you need to stop... Stainless steel brake lines are a MUST. maybe upgraded pads but at least the lines. |
02-11-2012, 02:24 PM | #5 | |
02-11-2012, 02:26 PM | #6 |
No sweat!
02-11-2012, 07:46 PM | #7 |
Drives: '69 SS Convertible Join Date: May 2009
Coilovers!
Looking into doing those. You'll be lowered yet have a smoother ride and if for some reason you decide to got drag racing or auto-X then a couple twist of some knobs and you're ready do go. With the money it looks as though you're spending, look into Pfadt coilovers. Otherwise I agree with IROCanSS on the other parts.
Build Journal |
02-12-2012, 07:24 AM | #8 | |
Thanks for the input guy's.
02-12-2012, 07:29 AM | #9 | ||
Sure if you are an all out autoX or drag racer for competition or something, great... or you have money to burn but for the weekend toy that may see the track once or twice... they are a TOTAL waste of money. Just look up the prices of Pfadt drop springs vs Pfadt coilovers. I think they are 8 to 10 times more expensive. Hey, like I said its your cash and if you have it to burn, go ahead but it isnt like all of a sudden your car will go from a sloppy mess and you'll turn a few knobs and its a race car... the weekend racer wont even notice the difference. Quote:
I hope you understood where I am coming from with the coils. I have drop springs and all the other stuff I listed.... I'd never swap out for coils. I have a custom race alignment and the car is on rails, I have no need to ever change it so why spend up to $2000 for coils. My springs cost me $200 shipped to my door. To me, unless youre hard core (which your OP says you are not) they are wasting money. Use the other $1800 for a nice Carbon Fiber drive shaft and the leftovers for Pfadt engine mounts! Dont just toss money away... my 2 cents... |
02-12-2012, 07:41 AM | #10 | |
02-12-2012, 06:35 PM | #11 | |
Drives: Camaro Justice Join Date: Jun 2007
02-12-2012, 09:15 PM | #12 | |
Drives: 2010 SS2 Camaro Join Date: Jun 2010
02-13-2012, 06:39 AM | #13 |
Since I'm not focusing on top end speed, the different gear ratio should give me the lower/mid-range torque/fun factor I'm trying to attain.
02-13-2012, 07:00 AM | #14 |
I.AM.
Drives: 2011 2SS/RS/A6 cammed-n-whippled Join Date: Oct 2008
Yes...you'll love the gears, they make a huge difference.
NY5thgen.com
Similar Threads | ||||
Any other additions to my suspension upgrade? | papabearcamaro | Suspension / Brakes / Chassis | 5 | 01-12-2012 03:44 PM |
I need Help Choosing a Suspension Upgrade. | 2012camaro2SS/RS | Suspension / Brakes / Chassis | 36 | 12-21-2011 01:30 AM |
C5 Community help needed for Suspension Upgrade | roccky08 | Suspension / Brakes / Chassis | 21 | 09-22-2010 10:13 PM |
Future suspension upgrade... | CamaroSS8491 | Suspension / Brakes / Chassis | 34 | 08-17-2010 02:57 PM |
