Old 07-09-2014, 09:27 PM   #1
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Drives: 13' ZL1 Red M6
SS vs. 1LE?
Has anyone here listed a total breakdown of the different parts between a SS and 1LE?
Here are a few I know of:
-SS Brembo's painted red
-PVC clean side oil separator
-1LE track suspension parts FE6
-NPP dual mode exhaust
-20x10 X 20x11 rims
-Matt black hood wrap
-3.91 gears
-Strut tower brace
Is there any other driveline upgrades? Tranny or differential coolers?
Mods:
Old 07-09-2014, 09:43 PM   #2
Midnight Rat
Midnight Rat's Avatar
Drives: SS 1LE
NPP can be ordered on a SS. 1le has to be ordered to.
Midnight Rat is offline   Reply With Quote
Old 07-09-2014, 10:19 PM   #3
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Good call.
Mods:
Old 07-09-2014, 10:43 PM   #4
BruHop
BruHop's Avatar
Drives: 2014 2SS 1LE,RS,NPP,Recaros in SW
The half shafts are beefier on the 1LE.
BruHop is offline   Reply With Quote
Old 07-09-2014, 10:45 PM   #5
BruHop
BruHop's Avatar
Front splitter.
Old 07-09-2014, 10:47 PM   #6
t&t moyer
It's all hers.
t&t moyer's Avatar
Drives: 2015 ZL1
Over the past two years it's been listed out countless times. Do a quick search and you'll find all the differences listed out by part number and you'll find the costs too.
Here's a start:
1LE Part Numbers
Also remember the transmission has close ration gearing and short throw shifter borrowed from the ZL1
1LE Diff (3.91) - 22806794
1LE 3.91 Gears only - 22813040 (fits SS and V6 manual)
1LE LH Axle - 22806795
1LE RH Axle - 22806796
1LE Front Sway Bar - 22812946
1LE Front Sway End Link (passenger side) - 22842515
1LE Front Sway End Link (drivers side) - 22842516
1LE Rear Sway Bar - 22786260 (same as ZL1, comes with brackets and bushings)
1LE Rear Sway Bar Endlink (2) - 22761221
1LE Rear Sway Bar Bracket Bolt (4) - 11518623
1LE/ZL1 Wheels 20x10 Black - 22798741
1LE/ZL1 Wheels 20x11 Black - 22798743
1LE/ZL1 Hubs - 22924741 (x2)
t&t moyer is offline   Reply With Quote
Old 07-09-2014, 11:29 PM   #7
Darwood
Here's a start:
1LE Part Numbers
Aren't the subframe bushings harder too or something like that. Definitive info on that seems hard to gather.
Darwood is offline   Reply With Quote
Old 07-09-2014, 11:32 PM   #8
ZWA SS
BowtieBelle's SS
ZWA SS's Avatar
Drives: 2010 Camaro SS
Suede wrapped steering wheel and shifter.
Anyone know part number for 1LE splitter?
Found!!
1le splitter-22950575
ZWA SS is offline   Reply With Quote
Old 07-10-2014, 01:29 AM   #9
Wildcherry13
Wildcherry13's Avatar
Drives: 2013 2SS/RS IOM 1LE
Also the zl1 fuel pump I believe.
Wildcherry13 is offline   Reply With Quote
Old 07-10-2014, 02:22 AM   #10
CHMSC
ROAD COURSE JUNKIE
CHMSC's Avatar
Drives: 2012 SS/RS LS3
Transmission has different gearing.
CHMSC is offline   Reply With Quote
Old 07-10-2014, 06:37 AM   #11
CamaroTom
CamaroTom's Avatar
Drives: 1/70 2013 BRM 2SS RS 1LE NPP NAV
The abs module and fuel pump control module have different programming. 1LE also borrows the transmission cooler from the ZL1. It does not have a diff cooler.
CamaroTom is offline   Reply With Quote
Old 07-10-2014, 07:20 AM   #12
Dropspeed
2013 Camaro SS1LECTSVZ28
Dropspeed's Avatar
Drives: 2013 AGM 1SS/1LE
As stated above, this has been covered dozens of times before
EXTERIOR/TRANSMISSION/INTERIOR
Exterior:
  • Forged aluminum ZL1 wheels 20x10 /20x11
  • Matte Black Hood, front splitter and rear spoiler
  • Red brembo brake calipers, 4 piston system
Transmission:
  • Six speed manual is standard
  • No Automatic transmission for Camaro 1LE
  • Tremec TR6060 Six speed Manual SS with 1LE Package
  • First: 2.66
  • Second: 1.78
  • Third: 1.30
  • Fourth: 1.00
  • Fifth: 0.74
  • Sixth: 0.50
  • Reverse: 2.90
  • Final drive ratio: 3.91
Interior:
  • Sueded-microfiber wrapped steering wheel and shift knob
OTHER DETAILS
  • Larger, 27-mm solid front stabilizer bar, and 28-mm solid rear stabilizer bar for awesome body control
  • Higher-capacity rear-axle half shafts to help with increased horsepower levels of traction
  • Strut tower brace for improved steering and response
  • ZL1 20 x 10-inch (front) and 20 x 11-inch (rear) aluminum wheels
  • 285/35ZR20 Goodyear Eagle Supercar G:2 tires front and rear ( same as the front tires for ZL1 )
  • ZL1 wheel bearings, toe links and rear shock mounts for track performance
  • ZL1 high-capacity fuel pump and additional fuel pickups for fuel delivery during high-load cornering. (2013 is 1LE only, ALL 2014 SS models have this fuel pump)
1LE Part Numbers:
  • Strut Tower Brace (LT, SS, 1LE) - 22756880
  • Wheel Hubs (ZL1, 1LE) (4) - 25954415
  • Front Coil Spring (SS, 1LE) (2) - 92245257
  • Front Strut (1LE) (passenger side) - 22812984
  • Front Strut (1LE) (driver side) - 22812985
  • Front Sway Bar (1LE) - 22812946
  • Front Sway End Link (SS, ZL1, 1LE) (passenger side) - 22842515
  • Front Sway End Link (SS, ZL1, 1LE) (driver side) - 22842516
  • Rear Shock Mount (ZL1, 1LE) (passenger side upper) - 22836734
  • Rear Shock Mount (ZL1, 1LE) (driver side upper) - 22836727
  • Rear Coil Spring (SS, 1LE) (2) - 92195466
  • Rear Shocks (1LE) (2) - 22812987
  • Rear Sway Bar (ZL1, 1LE) - 22786260
  • Rear Sway Bar Endlink (SS, ZL1, 1LE) (2) - 22761221
  • Rear Lower Control Arm (SS, ZL1, 1LE) (2) - 20942237 (Needed for 2010-2011 car conversion)
  • Rear Toe Link (ZL1, 1LE) (2) - 22845487
  • 3.91 Gears only ( 1LE ) - 22813040
  • Front Splitter kit ( 1LE ) - 22950575
  • Wheels 20x10 Black ( ZL1-1LE ) - 22798741
  • Wheels 20x11 Black ( ZL1-1LE ) - 22798743
In 2013 the 1LE did get the ZL1 fuel pump. For 2014+ all V8 models (SS and SS/1LE) get the ZL1 Fuel pump.
Matt
Old 07-10-2014, 12:05 PM   #13
GONIF
GONIF's Avatar
Drives: 73 VETTE ,, 05 2500hd diesel,14 1LE
Found!!
Not suede ,thats fake suede called Alcantara .
OLD GUY FLYING FAST AND LOW
GONIF is offline   Reply With Quote
Old 07-10-2014, 03:07 PM   #14
Mark T
American Gold Whisperer
Drives: 2014 White 1LE 2SS/RS/NPP/Rec/Nav
$3500... thats the difference that gets you an SS with the 1LE performance option.
It is a no brainer... get both, and get the best.
Mark T is offline   Reply With Quote
