Old 02-16-2017, 08:29 PM   #1
Btrbimmer
Drives: 2SS 1LE Silver w/Recaro NPP
Recommendation for low cost track wheels/tires? OEM 2016 SS takeoffs?
I'm looking for a set of wheels/tires for track events for my '14 1LE. I have not seen any sets for sale used, so I'm thinking of a set of 2016 SS takeoffs.
I'd prefer a "square" fitment, so I can rotate the tires for wear.
Also, would prefer going with a smaller diameter if possible.
Any suggestions or insight would be appreciated.
Thanks!
-BtrBimmer
'14 2SS 1LE NPP Recaros
Btrbimmer is offline   Reply With Quote
Old 02-16-2017, 08:35 PM   #2
appleman22
Drives: 2017 1ss 1le
i'm not sure the 16 ss wheels fit without spacers unfortunately
appleman22 is offline   Reply With Quote
Old 02-16-2017, 09:01 PM   #3
pbsinternet1le
pbsinternet1le's Avatar
Drives: 2017 1le current /2015 2ss 1le sold
I have a set of mrr 228 if your interested..with tpms. Same size as stock 1le
2017 1LE Hyper Blue
pbsinternet1le is offline   Reply With Quote
Old 02-16-2017, 09:01 PM   #4
Synner
Drives: cars
I've had forgestar CF5's that have worked well. I did 20x10.5 but not square offsets. You could easily do 19x10. The prices are very reasonable for custom offset wheels.
Avoid the CF5V, they're too light and not strong enough for our portly cars without going fully forged. I would not use a cast wheel for track duty, minimum of rotary forged and forged if you will use something close to slicks.
Old 02-16-2017, 10:16 PM   #5
Dropspeed
2013 Camaro SS1LECTSVZ28
Dropspeed's Avatar
Drives: 2013 AGM 1SS/1LE
I have a set of 4, 18X10 ET 25 ApexRaceparts PS-7 wheels with 305/35/18 Nitto NT-01 with tons of tread left. Requires extended studs installed and 10mm spacer on the front wheels to clear upper part of the knuckle. I am not tracking my 1LE anymore (picked up a Corvette) and have 2 sets of Apex wheels including another set of 4 (18x11) that I don't need.
https://www.apexraceparts.com/wheels...s-7-wheel.html
4 18X10 ET25 Apex PS-7
2 Aluminum 10mm hub centric spacer
4 Aluminum hub centric rings
10 GM extended wheel studs (new in bag)
4 Nitto NT-01
4 TPMS sensors
4 Center caps
$1600 shipped in the 48
-Matt
Pictures of the tires in the rack were taken tonight. Lots of tread left!
Old 02-16-2017, 11:24 PM   #6
CamaroDreams76
Tri-County Camaro SWFL
CamaroDreams76's Avatar
Drives: 2013 IOM 2SS/RS/1LE
4 Nitto NT-01
4 TPMS sensors
4 Center caps
-Matt
Will these clear the rollerskates?
Old 02-17-2017, 06:51 AM   #7
Dropspeed
Dropspeed's Avatar
I had them over 6 piston Corvette calipers and AP Racing Calipers so I can not confirm, but I doubt it.
They are very easy to cut off.....If you're buying 18s to track a car you should probably replace the pads with something more aggressive at that time. Aftermarket pads don't have rollerskates.
Old 02-17-2017, 12:28 PM   #8
Notilloc
Notilloc's Avatar
Drives: 2015 Chevy Camaro SS 1LE
4 Nitto NT-01
4 TPMS sensors
4 Center caps
-Matt
Pm sent
Notilloc is offline   Reply With Quote
