#Camaro6
Go Back   CAMARO6 > Engine | Drivetrain | Powertrain Technical Discussions > V8 LT1 Engine, Exhaust, and Bolt-Ons
AWE Tuning
Old 08-09-2018, 09:04 AM   #1
nightfallcamaro
nightfallcamaro's Avatar
Drives: 2016 Nightfall Grey Camaro 1SS
E85 GAINS ON 2016 1SS A8
So I just wanted some feedback to see if people thought my numbers are accurate to what they should be. The graph I attached is of the final e85 run.
Here are my current mods:
  • Rotofab CAI
  • VMAX ported throttle body
  • Stainless Works 1 7/8 headers (no cats)
  • Stainless Works 3 inch exhaust
  • Flex Fuel
93 tune:
410whp, 433wtrq
e85 tune:
451whp, 472wtrq
LT4 Supercharger | Rotofab Intake | Ported Throttle Body | Stainless Works Exhaust | Flex Fuel
https://www.instagram.com/nightfallcamaro/
nightfallcamaro is offline   Reply With Quote
Old 08-09-2018, 09:13 AM   #2
parish8
Drives: 17 SS a8
The gains from pump to e85 seems right.
Your numbers seem a little low compared to what I got. I was about the same hp but without headers or exhaust. I did have all 4 cats deleted. I was also on a dynojet.
dropped a valve in the 6.2. now running a drop in rods and piston 5.3
best et 5.83@121 with the 5.3 http://www.camaro6.com/forums/showthread.php?t=465472
parish8 is offline   Reply With Quote
Old 08-09-2018, 09:25 AM   #3
nightfallcamaro
See that's what I figured. I even told my mechanic. I was happy but I was expecting 470whp/490trq. A little enthusiastic I know, but in the ballpark.
Even at 460 I would have been estatic.
Old 08-09-2018, 09:30 AM   #4
danhr
BAMF SS
danhr's Avatar
Drives: 2016 Camaro 1SS A8
Send a message via AIM to danhr
Without a baseline and knowing which correction factor (if one was even used), it's moot.
Could just of been a hot day and a correction factor wasnt used and it could be really high numbers
Or could be a low reading dyno and you have really high numbers
Or vice versa
2016 1SS A8: FBO + Circle D + P1X + Meth + Tuned by Pray Performance
Stock Longblock
800 SAE rwhp. 9.4 @ 145 mph.
danhr is offline   Reply With Quote
Old 08-09-2018, 09:42 AM   #5
nightfallcamaro
Or vice versa
I saw it was in standard so I know that much. As far as correction factor I wouldn't know what to tell you, I would have to talk with my tuner.
I have heard from other people that the dyno does read low.
My concern is that I put down 426whp/449wtrq on 93 the very first time I tuned the car which was about a year and some 20k miles ago. It didn't do nearly as well on the 93 baseline when we started tuning for e85.
Old 08-09-2018, 12:38 PM   #6
PRAY
PRAY's Avatar
Drives: 2016 2SS
I have never seen over a 25rw gain with E. NEVER. 41rw on E is a bit ridiculous. So either the pump gas tune was way off or something is up.
I don't think the numbers are all that low if at all for an A8 in what I will assume is 5th gear. 6th gear would have shown 20-30rw depending on the car. The STD correction factor will inflate those numbers 10-12rw over SAE though. A ported IM would have helped you out a bit.
PRAY is offline   Reply With Quote
Old 08-09-2018, 12:46 PM   #7
nightfallcamaro
I just watched the video of the last pull and it sounds like he went up to 6th gear.
I've been considering a ported manifold but given that I'm eventually going to do forced induction, my mechanic advised me against it due to cost vs performance.
Here is a link of the last run so everyone can see for themselves.
Old 08-09-2018, 12:50 PM   #8
PRAY
PRAY's Avatar
Drives: 2016 2SS
So the base line was in 5th and the final pull was in 6th? I guess that could make sense.
Old 08-09-2018, 12:56 PM   #9
nightfallcamaro
Oh I have no idea, I really wasn't paying attention when he was doing the baseline.
You're saying 5th gear would show a lower number?
Old 08-09-2018, 01:01 PM   #10
PRAY
PRAY's Avatar
Drives: 2016 2SS
Yes, 5th gear is a 1.27, 6th gear is the 1:1. I have seen no less than a 20rw gain from 5th to 6th and I have seen some cars as high as 30+rw. 5th gear will always show lower numbers.
Old 08-09-2018, 01:12 PM   #11
nightfallcamaro
Got it thank you for taking the time to explain my friend, I guess I'm understanding the nature of the numbers better and now I don't feel as bad haha
Old 08-09-2018, 01:27 PM   #12
JaxChris
Drives: '16 2SS GD1 MX0 NPP F55 IO6
EDIT: I had typed this before Pray replied, removing because all the same is already provided above.
JaxChris is offline   Reply With Quote
dyno, e85, flex fuel, headers, tuning
