#Camaro6
BeckyD @ James Martin Chevy
Old 12-14-2020, 07:01 PM   #1
kreh
Drives: Chevrolet Camaro 1LT RS
Smile Tuning
Is there any handheld tune holders I could get? I don’t know what a better name for it is, but a way to quickly select between different tunes, or turn off a specific tune, I want to tune my car to make it pop, but don’t want it to be popping and crackling when I leave the house early in the morning. I have a V6.
Also is there anyway, to make the car make LESS hp rather then more? The only reason for this is to help me drive in the winter lol.
kreh is offline   Reply With Quote
Old 12-14-2020, 11:28 PM   #2
Mark114
Mark114's Avatar
Drives: 2016 2SS Convertible
Put the car in Snow/Ice Mode.
Mark114 is offline   Reply With Quote
Old 12-15-2020, 08:50 AM   #3
HCI2000SS
HCI2000SS's Avatar
Drives: 2018 Camaro V6/RS
Like mentioned above snow/ice mode sounds like your best bet
HCI2000SS is offline   Reply With Quote
Old 12-15-2020, 09:49 AM   #4
arpad_m
arpad_m's Avatar
Drives: 2018 Camaro 2SS A8
As others said, snow/ice mode is the most limited out of the box. Have you tried it? Was the car still too powerful or the throttle too responsive even in that mode? My recollection of the V6 is that it won't lurch or spin the tires unless you really want it to...
Even if handheld "tune switchers" do exist, I wouldn't use them, because if they rewrite the tune every time you "switch", I'd be concerned about flash storage wear inside the ECM.
On the other hand, an OBD-II device can modify inputs or generate fake ones, theoretically it could also reduce performance. However, so far I've only heard of power boosters such as RaceChip, but even that is only available for the I4
735 rwhp | 665 rwtq
Magnuson TVS 2300 80mm pulley | Kooks 1 7/8" LT headers | JRE smooth idle terminator cam | LT4 FS & injectors | TSP forged pistons & rods
JMS PowerMAX | DSX flex fuel kit | Roto-Fab CAI | Soler 95mm LT5 TB | 1LE wheels | 1LE brakes | BMR rear cradle lockout | JRE custom tune
1100 - 1/30/18 | 2000 - 1/31/18
3000 - 2/06/18 TPW 2/26/18
3400 - 2/19/18 | 3800 - 2/26/18
4300 - 2/27/18 | 4B00 - 3/01/18
4200 - 3/05/18 | 4800 - 3/14/18
5000 - 3/16/18 | 6000 - 3/19/18
arpad_m is offline   Reply With Quote
Old 12-15-2020, 04:41 PM   #5
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
If I'm not mistaken from what I know and have read over the years about the popping and crackling on any of theses cars, you can't "adjust" it you can only tune it out, or leave it there. It is what's called DFCO..." Deceleration Fuel Cutoff". When you let off the throttle the ECM shuts off the fuel to the injectors and hence air is introduced and no fuel, so it pops and crackles. With an aftermarket exhaust it is really loud.
Old 12-17-2020, 07:10 AM   #6
z28pat
z28pat's Avatar
Drives: 2002 z28, 2018 2ss 1LE
I Used to live in Antioch ill, your best bet is the snow/ice mode and maybe an extra set of wheels with winter tires, extra weight in the back helps the car hook as well.
z28pat is offline   Reply With Quote
Old 12-17-2020, 08:15 AM   #7
Joshinator99
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
This^^^
I’ll date myself with an old timer story, but back in the day I had a new ‘97 WS6 Formula that was my daily driver (when you’re young you gotta rock it year round &#128514. For the winter, I finally broke down and bought a set of base model Firebird wheels and put winter tires on it. I was absolutely stunned at how much better it was in the snow.
2017 Chevy Camaro 2SS A8 Whipple 3.0, Mast Black Label heads, Fore triple in-tank pumps, 112mm TB, LPE +52% injectors, LPE BB HPFP, 15” conversion 1059 WHP/944 WTQ, 9.48@150
Joshinator99 is offline   Reply With Quote
pops, tune, tuner, tuning
