05-21-2010, 08:20 AM | #1 |
Drives: 2010 Camaro 1ss aqua blue Join Date: Dec 2009
What else can I do??
Ok I have on order.
1. Billy Boats 3" sport Catback Exhaust Threw "Maryland Speed" 2. Kooks 1 7/8 headers with 3x3 High Flow Cats Threw "My local Dealer" 3. "CAI" Cold Air Intake. Threw "Apex Motorsports" 4. My local Chevrolet Dealer has a Performance division equipped with Dyno and they will be doing the install and tune. So with out doing major reconstructive surgery on my engine with a cam or supercharger, what else do you good people suggest I can do to get more performance out of my camaro? I have a 1SS automatic by the way. Thank you too all that reply.
05-21-2010, 08:39 AM | #2 |
Resident Engineer
Drives: 2010 Camaro SS, 1988 GMC S-15 Join Date: Jun 2009
i believe you pretty much have the bolt-on side taken care of. I would maybe port the intake manifold and throttle body, pulley change, and i think that's about it. But that would require taking apart some things.
12.68 @ 109: LSR cai, Borla S-type axle-back, Tunes |
05-21-2010, 08:39 AM | #3 |
Drives: 2010 Camaro SS, 2008 Heritage 300C Join Date: Jun 2009
Nitrous
05-21-2010, 08:41 AM | #4 |
Resident Engineer
05-21-2010, 08:49 AM | #5 |
Drives: 2010 Camaro 2SS/RS Join Date: Mar 2010
JayC, is the dealer going to maintain your power train warranty since they are doing the tune? Just curious.
2010 Camaro 2SS/RS
Imperial Blue | Grey two-tone Interior | Silver racing stripes | Magnaflow Comp Cat-back | CAI intake | Elite Engineering Tunnel Brace | Richmond (Houston), TX |
05-21-2010, 08:50 AM | #6 |
Drives: '69 SS Convertible Join Date: May 2009
What about going into the suspension now. Springs, Sway Bars, Trailing Arms, Toe Rods, Bushings.....etc.
What about gears. A set of 4.10s will wake the car up even more! If you have an M6 I would put in an aftermarket shifter......I suggest MGW Have you taken it out to a drag strip and try to see what it will run? That's where you'll probably see that you need some suspension stuff and/or race wheels/tires.
Build Journal |
05-21-2010, 08:51 AM | #7 |
Resident Engineer
drag radials will definitely help the car out!
05-21-2010, 08:55 AM | #8 |
Drives: 2010 2SS IOM L99 Join Date: Jan 2010
cam
05-21-2010, 09:19 AM | #9 | |
Drives: Gray Join Date: Oct 2009
Re: What else can I do??
05-21-2010, 09:26 AM | #10 |
I did ask him about this and his response was, yes 100%. The guy im talking to is the manager over the entire shop and he has assured me that I will be covered. He and alot of the employees there have camaros with cams and superchargers on them. I trust him and im happy to be working so close with a dealer. Cause if I do have a problem, they did all the work.
05-21-2010, 09:29 AM | #11 |
[QUOTE=Have you taken it out to a drag strip and try to see what it will run? That's where you'll probably see that you need some suspension stuff and/or race wheels/tires.[/QUOTE]
I just purchased everything yesterday, so it will probably be a month or so before I can do that. But I will and will post the results as soon as I can.
05-21-2010, 09:41 AM | #12 |
Ahhhh......I see a new set of Trailing Arms and drag radials in your near future...
Suddenly you'll be trolling the Suspension Section as I did after my first trip to the track. When/If you get to the point of needing Trailing Arms....look at Spohn (Del-Sphere version), BMR, or Pfadt.
Build Journal |
05-21-2010, 10:49 AM | #13 |
Anyways, suspension would be a good way to go. That will help get more power to the ground. Drag radials is a good thing too, I'm trying to find some for mine but I'm having problems with that...lol I don't know were to look! Last edited by mcdoogle6969; 05-21-2010 at 12:17 PM. |
05-21-2010, 11:53 AM | #14 |
gmag21
lol suspention
L99 | Billyboat Exhaust, American Racing Headers, Pfadt Springs and Sways, Tune | 350 whp / 371 tq |
